Active Member
![]() Join Date: Feb 2011
Door alignment after new door seals off?
After putting new door seals both sides on my truck, the doors want to stickout about a quarter inch. i have to really slam them to get them to shut though. Did this happen to anyone else? Also, will they break in over time and use?
![]() Join Date: Nov 2011
Re: Door alignment after new door seals off?
I'm just about ready to put new seals on... looking forward to seeing what the advice is on this...
some door seal are better than others, the ones from lmc and some other companys arent very good and take awhile to soften up and break in. I think there is a guy on the site here who sells them and ive heard there pretty good. i put new ones on reajusted my door and the driver side wasnt bad after a year but the pass was still tight
_________________________________ 62 Impala 70 C-10 LWB 71 K-10 SWB 85 C-10 LWB==SOLD 01 2500 HD Members Met......2003Silverado (Dave) |
Moderator
![]() Join Date: May 2007
GMCPaul sells press-on style door seals. They are the BEST, hands down: http://67-72chevytrucks.com/vboard/s...d.php?t=438649
Whatever seals you use, they will need to break in over time.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
GMCpaul..............good call couldnt remember his name
Active Member
Thanks a bunch guys, i may invest in some of gmcpauls stuff then if the word is good.
How about window and vent window seals? What have you guys liked and recomended involving them? |
heating up the door seals with a hair dryer or VERY CAREFULLY with a heat gun can help somewhat im making them give a bit to aid the problem it is especially helpfull in the frigid winter weather
I used cheap glue-ons from a local shop that made me slam my doors. After about 6 months there starting to get worked in. I'm hoping they will get better when the temp outside gets warmer.
Old Duffer
![]() Join Date: Mar 2003
If you're not adverse to silicon spray, get a can of it, spray a little on a rag and carefully wipe the gasket with it. It doesn't soften the gasket, but will allow it to slide against the door a little easier until the weather seal takes a set.
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
this is a bad time of year to do that because of the cold weather, most companies will tell you to put seals on close doors and leave them in the hot sun for 3 to 4 days, but that don't work, how do i know i tried this , my door seals came from brothers, like probably everybody else's did , made in china. The best ones i've used is softseal there worth the money.but be prepared to pay 3x for them. If you pay attention to gm seals most of them had vent holes in them, that's why the worked. did this to my first set of china made seals and it helped .
