Old 02-12-2012, 03:44 PM   #1
mccurrkm
mccurrkm's Avatar
Motor Mount Adapter Help
Hey guys...I am working on a LS swap for my 85 Chevy c10 2wd. I just bought an 86 that has a 2005 6.0 and 4l80e already in it. I am going to use it as a parts donor for mine. When trying to get an idea of where he left the project, I was asking the guy about all the parts he put in it. When asking him about which adapter plates he used to mount the motor mounts, he said "It just sat down in there man and bolted right to the stock mounts." I'm starting to think he didn't do much of the work. Here is a picture of the stock motor mounts bolted to what appears to be the adapter plates...I'm new at this so I need a little help identifying what adapter plates these are or if I'm even looking at the right thing. Anyone know which ones these are? Thanks for your help...this forum is awesome!
mccurrkm is offline   Reply With Quote
Old 02-12-2012, 05:32 PM   #2
mooseknuckles
mooseknuckles's Avatar
Re: Motor Mount Adapter Help
I think they're ls1 adapter plates....lol...idk man.
mooseknuckles is offline   Reply With Quote
Old 02-13-2012, 09:35 AM   #3
mccurrkm
mccurrkm's Avatar
lol... I don't know either. I know he didn't just bolt the stock motor mounts up to the block, but I don't know which adapter plates he used. Apparently, he doesn't either. I would just like to know exactly which parts were used. The driver side has something engraved in it too but I can't see what it says. I think it may say LS1 too.
Old 03-22-2012, 12:32 PM   #4
mccurrkm
mccurrkm's Avatar
Can anyone tell if this has the motor sitting forward or back? Any estimates on how much? This picture is taken from the front of the engine looking towards the rear on the passenger side. I know this is a strange question, just trying to get all the details worked out.
Old 03-23-2012, 12:27 AM   #5
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Take a pic directly from the side looking at the front of it with the rad in the pic as well and tell us what the distance is inbetween the block and your rad.
Then do the same in the rear between your block and the firewall.
Then say whether you are going to use a mechanical fan or an electric fan set up. Then we might know enough info to help.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 03-23-2012, 10:30 AM   #6
mccurrkm
mccurrkm's Avatar
Ok I will try to get those today when I get home. Thanks!
Old 03-25-2012, 11:54 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
those look like the standard "swap adapter" plates, with the exception that they have an additional plate of thickness welded on at the mount point....and I'm not sure why. From what I can tell, the engine is sitting forward 1-2"
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
