Old 02-12-2012, 07:29 PM   #1
68c20lwb
68c20lwb's Avatar
Lmc
i bought a power steering pump pulley for my 72 no a/c and either direction i put the pulley on, it doesn't line up with the accessory drive. any suggestions or tips?
1968 C20 450hp 425ft-lbs 454/SM465 4.56's 2004 HD rims, needs paint and a 5th gear!
1969 C30 Open Road Motorhome 350/th400
1972 K10 350/350/205 Daily Driver -SOLD
68c20lwb is offline   Reply With Quote
Old 02-12-2012, 08:22 PM   #2
rsavage
rsavage's Avatar
Re: Lmc
Hard to tell. You could have the wrong crank pulley set up ( power steering runs on the third pulley out or the second which is deep if non ac. Call this guy Jim. He sells on ebay as gotpulley and lists his numbers in the ads so I am not violating his privacy. He is super knowledgeable on what you will need and sells used pulleys. You will need to tell him what pulleys you have now, long or short water pump (should be short if your alternator is on the driver's side as it should be) etc. His name is Jim - he lives in AZ 480-981-3096 or 602-751-0454.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 02-12-2012, 08:32 PM   #3
68c20lwb
68c20lwb's Avatar
Re: Lmc
thanks for your reply, i will check him out
