Old 02-12-2012, 10:24 PM   #1
allaboutchevelles
allaboutchevelles's Avatar
01 silverado 4.8 knocking
Hey guys, Im from the 60-66 C10 forum room mostly. I have been having problems with my DD for a while now. Its a 01 silverado ext cab 2 wheel drive with the 4.8 engine. For the last about 2 years every time I start it after sitting for several hours the motor has a bad KNOCKING sound. It goes away right after the motor warms up for about 3 or 4 minutes. Ive heard alot of problems with this and chevrolet says it will not hurt anything. The truck only has 95,000 miles on it with regular oil changes every 3500 miles. What is causing this and is there anything to do to fix it??? Thanks!!
69 chevelle malibu, 64 C-10 shortbed
allaboutchevelles is offline   Reply With Quote
Old 02-12-2012, 10:42 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: 01 silverado 4.8 knocking
Sounds like Cold Start Knock. I've had them do it when the temp drops below 50, but in the summer they are fine. Sucking a bottle of seafoam through the brake booster hose seems to help it short term, but no long term fix. Does the oil press fluctuate while its knocking?
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 02-12-2012, 10:48 PM   #3
463
463's Avatar
Gm calls it piston slap. I hope it has a WIX 51522 or a AC DELCO PF46 oil filter.
Trueman
463 is offline   Reply With Quote
Old 02-12-2012, 10:59 PM   #4
clinebarger
Cold piston slap on Gen III engines is normal, I had a 97 Corvette LS1 that would sound like it was coming apart untill it warmed up.
If it takes a little while to build oil pressure & the rods are rattling, The O-ring on the oil pump pick-up needs to be changed.
clinebarger is offline   Reply With Quote
Old 02-12-2012, 11:21 PM   #5
allaboutchevelles
Thanks for replys guys. The oil pressure stays way up the whole time like on 60. I normally run a AC delco filter or a wix from carquest. not sure of the part numbers of the filters.
Old 02-13-2012, 09:32 PM   #6
gregory5000
Yep like the others said it is a common thing. My truck does it. You are also changing your oil too much. It is not hurting anything, but it is not helping anything either, just hurts your wallet.
2001 GMC 2WD, 1998 Chevy K2500
gregory5000 is offline   Reply With Quote
Old 02-13-2012, 09:47 PM   #7
spudz
spudz's Avatar
Normal. Its piston slap.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 02-14-2012, 09:25 PM   #8
truckdude239
truckdude239's Avatar
its normal always runa good brand filter wix ac delco or purealtor
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
