screws
Does anyone know the details as to what the attaching hardware is for the regulator mounted on the radiator support.
It appears to be a rubber isolator with screws. Where can they be found? Thanks for any help. ![]()
Richard Dobson |
You can buy the hardware from most vendors. The nuts are molded into rubber and you push the rubber into the holes in the radiator support and the the regulator. As you tighten the screws, the nut is drawn in and causes the rubber to "bulge" and hold the nut for tightening. The screws are a shoulder design to keep from overtightening them. There are three screws and three nuts for fastening the regulator to the radiator support.
Jim |
