Old 02-13-2012, 03:06 PM   #1
shoebox
67 c 20 power stearing hoses
i have a 1967 c20 with power stearing (power assist) iam needing new hoses
any one know where to find them
shoebox is offline   Reply With Quote
Old 02-13-2012, 03:13 PM   #2
chewychevy67
Re: 67 c 20 power stearing hoses
i have been looking for quite a while myself with no luck. even tried locally to have my originals rehosed with no luck so if anyone knows where to get new ones im interested as well.
chewychevy67 is offline   Reply With Quote
Old 02-13-2012, 03:44 PM   #3
Sammy
You should be able to have a set custom made. And it isn't outrages to have done. I had a custom pressure power steering line made it was about $12. {new was like $24 made in China) Look for a shop that does lines for tractors and heavy equipment and use the small shops they are more reasonable than the big tractor places. Ask around.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 02-16-2012, 10:51 AM   #4
shoebox
i went to every auto parts in town no luck called kellys truck parts they had 2 nos hoses for the lower unit bought them went to hydrolic supply and had the high pressure line built ,they had to cut off my old hard lines and braze them on new fittings expensive but i had no choice they look good
Old 02-16-2012, 11:44 AM   #5
chewychevy67
I wonder if you could get some custom made in stainless like another board member did for the big block trucks?
Old 02-16-2012, 02:20 PM   #6
john
member #16
john's Avatar
From what i've read, corvette used the ram assist until 1982. Some of the cyl lines and seal kits should fit our trucks.
https://www.google.com/#hl=en&gs_nf=...w=1536&bih=710
john is offline   Reply With Quote
Old 02-16-2012, 03:11 PM   #7
chewychevy67
the components for all early chevys with these are the same except the hoses. they differ from vehicle to vehicle as the valve is different distances from the ram in each vehicle.
Old 02-22-2012, 12:35 AM   #8
chewychevy67
do you have the part #'s for the 2 lower hoses?
Old 02-22-2012, 12:57 AM   #9
ItsRandy
ItsRandy's Avatar
Looks like the Truck Shop has the hoses you are looking for.
http://www.truckandcarshop.com/
ItsRandy is offline   Reply With Quote
Old 02-22-2012, 09:01 AM   #10
chewychevy67
are the 66 style hoses the same a s the 67 68 hoses?
Old 02-22-2012, 09:12 AM   #11
duallyjams
duallyjams's Avatar
Try looking for a hydraulic cylinder repair shop they can make any type hose that you need.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 03-30-2012, 05:32 PM   #12
chewychevy67
i orderede the ones from truck and car shop and the hoses that go from the cylender to the valve arent even close to fitting. they dont look anything like the picture in their catalog.
