Hood Adjustment?
Most cars I have worked on in the past have screw deals to adjust the front corners of the hood. My burb doesnt have any nor have I seen any place that they would have been. Am I missing something simple?
Re: Hood Adjustment?
the only setting are the two bumpers on either front corner and the two in the rear on little brackets
#3 | |
I know I have seen this on some trucks (like my 68) and it can thow you off because the hole is usually large, and there is a body clip (threaded) that pops in that hole and creates the thread for the adjustment bolt... hope this helps
2004 Corvette Coupe Black LS1 (daily driver) 1973 Ford Bronco (resto/mod @ 95%) 1991 GMC sportside Pickup Truck, 468c.i.d. ('nuff said) 1997 Ford F150 4.2L 500k+ miles (trash hauler) 2011 Nissan Juke (wife's daily driver) 1943 Ford GPW WWII jeep (waiting its' turn) |
two fronts keep metal apart, 2 backs line up fenders and sheet metal
hmmm let me go look again...
It looks like there are two holes in the hood itself that may be what they are used for, holes are very small and of course missing the bump stops.
Senior Enthusiast
There are no screw post adjusters on our hoods. Adjustments are done at the hinges, and by the height of the hood latch post. Post #16 on the following thread shows the factory adjustments from the shop manual:
http://67-72chevytrucks.com/vboard/s...ht=hood+hinges |
#8 | |
Right now my hood closes and is metal on metal so apparently I am missing the outer bumpers ![]() |
Senior Enthusiast
Yes they are solid rubber square blocks that screw to the outer corners of the hood.
My camera just didn't want to focus on these, but here's some pics of the front and rear hood bumpers on our burb...
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
Thanks for the pics, my hood has the rear ones but not the front. Looks like LMC has some rivet ones.
