Old 02-13-2012, 06:07 PM   #1
vegas80step
vegas80step's Avatar
power window wiring???
OK.. time to wire up my power windows..
I switched over from the cranks and was told I should run everything through relays or I would burn out the buttons?? True?
If so, any one have a wire diagram...?
Any other tips?
I drive a lowered Chevy, a lifted Ford and I have a 62 VW bug stripped down in the garage.
Which "Piss on" sticker do I buy?
vegas80step is offline   Reply With Quote
Old 02-14-2012, 03:26 PM   #2
JMS-1
JMS-1's Avatar
Re: power window wiring???
I can’t be of much help, but I am in the process of converting my truck . Did you buy an aftermarket kit or are you using stock GM components and wiring? I’m trying to find the best way also.
1980 converted C30 454, 4 on the floor...
JMS-1 is offline   Reply With Quote
Old 02-14-2012, 03:36 PM   #3
vegas80step
I went with a kit, mostly because I also went with the one piece window. It was a full kit to do one piece and power.
