Old 02-13-2012, 09:51 PM   #1
Hardrockz28
Locking gas cap no key
Ok I have problem, pick up a 66 truck that the owner was rebuilding the truck and he lost the key. How do I remove it with out making a mess of the filler tube
Hardrockz28 is offline   Reply With Quote
Old 02-13-2012, 10:00 PM   #2
krazy_texan
krazy_texan's Avatar
Re: Locking gas cap no key
either a drill or a hammer and punch should do the trick just got to be careful not to get to much crap in the tank.
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 02-13-2012, 10:06 PM   #3
cris well
Does it look like this one?
I just ran a short sheet metal screw in mine and caught the inner part--it will come off then.
Mine still has the screw in it from a few years ago.
I can send you a pic tomorrow if you need it.
cris well is offline   Reply With Quote
Old 02-13-2012, 10:37 PM   #4
Hardrockz28
No not one like that one it's a steel gas cap
Old 02-13-2012, 10:49 PM   #5
kenmel
kenmel's Avatar
I used a hammer and a big flat blade screwdriver and mine came of pretty easy. Locking gas caps are junk lol but it slows thiefs down enough to hopefully make them look elsewhere.
kenmel is offline   Reply With Quote
Old 02-14-2012, 07:13 AM   #6
tazattitude
tazattitude's Avatar
Can you get behind the seat and unclamp the tube. Remove the tube, then either work from the inside of the tube of remove the cap from the outside. This way, if small shavings or parts fall out, they don't go in the tank.
TAZ
BUILDS
1966 GMC Suburban
1963 GMC Suburban Patina frame-on FOR Sale
1966 C10 Short Bed (2010-11)
Monthly Updates
2015 C10 Pics with my '72 Montego GT 429/521 build
1963 Pro Street C10 back halved. Frame off I did back in 1990
Pics / Video
tazattitude is offline   Reply With Quote
Old 02-14-2012, 09:28 AM   #7
T Smith
T Smith's Avatar
Brilliant!
T Smith is offline   Reply With Quote
Old 02-14-2012, 09:29 AM   #8
1963c-10
1963c-10's Avatar
This is the way that i'd go.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 02-14-2012, 10:24 AM   #9
tomfg
However you decide to remove the locking gas cap,
I think I would refrain from "Making Sparks"!!!!
tomfg is offline   Reply With Quote
Old 02-14-2012, 12:49 PM   #10
T2vigil
T2vigil's Avatar
That is also Brilliant.
T2vigil is offline   Reply With Quote
Old 02-14-2012, 01:00 PM   #11
cris well
If you have this style of oil filter wrench you may be able to twist it and break the lock??
Old 02-14-2012, 03:53 PM   #12
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
66 has an abs plastic filler tube, it would probably break before the cap would... Before i read taz's post I was going to suggest what he did... probably the best method, I actually did ths last year, once the tube was off there were 2 small screws under the cap and it was done!
Old 02-14-2012, 08:12 PM   #13
k1rodeoboater
I lost the keys to my truck which had my gas cap key on it....I'm just gonna try buying another gas cap and using the keys from that. Generally speaking they're all keyed the same ironically.
Worst case I'll pick the lock. It's not that hard to do if you have/make the right tools.
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201
no garage, no shop, limited storage space and tools....no problem.
k1rodeoboater is offline   Reply With Quote
