WTB: cab frame mount, Upper control arm mount
Hey folks,
I need the passenger side rear cab frame mount and the passenger side upper control arm mount, among other steering items. Mine are rusted to hell on the frame. Let me know what you've got! For a 69 c10. |
![]() Join Date: Apr 2007
Re: WTB: cab frame mount, Upper control arm mount
I should have that,I can check tomorrow for sure what else do you need?
So far, those are the two really important items so that I can get this thing to powdercoating. I need to replace a fair amount of the front steering and suspension, but that may have to come a little later, solely because of the almighty dollar :/
So you want the bracket that tha upper control arm mounts to and that in turn is bolted to the frame rail,but not the control arm,correct? Also the bracket on the frame that the rubber rubber cab mount sits on top of. I have read on this site that 3/4 ton mounts differ from 1/2 ton although Ive also read that the frames 1/2 and 3/4 ton are the same,so I'm not really sure why they would be diffrent. My question being are the frame brackets diffrent or not? I should have both but not all will be good I'm sure. How bad is the one on your truck? Ive fixed a lot of them by welding a big washer on top to resize the hole. Most rot right where the cab mount sits.
If you want to come pull them you can have them.
Im in orlando |
#6 | |
The cab mount is shot out, where the cab sits and then some. I'd rather bolt a new one in than weld this guy. I'm looking to replace most rivets anyway. |
![]() Join Date: Sep 2010
what all you need ? i m pulling all the 2wd stuff off a 67 or 68 frame will sell whatever cheap. i have the upper and lower arms sold already but everything else is for sale
If you can find what you need faster or better don't wait on me I still need to go see what I have and there are no for sures here.Just trying to help but dont want you to miss on a sure thing.
