Old 02-14-2012, 10:24 AM   #1
Blacksunshine87
The best 4-link set up!?
Hello everyone ! I'm new here and thought this place could be helpful.
Anyway I recently purchased an 87 2wd short box. I have always loved these trucks. I wanna start with the rear suspension first. I found a 12 bolt rear which should work fine for what I want. The important question is what 4-link set up to choose. I'm not really a fabricator so I'd would be a little Leary of a weld in unit. And also what style to go with? Parallel of triangulated ? I want this truck to be a cruiser but also want to take to the local dragstrip once in a while as well. Defineatly want to bag it for a smoother ride. If anyone could toss out some ideas it would be very much appreciated as to what set up you choose and how much you like it. Thanks!! Allen
Blacksunshine87 is offline   Reply With Quote
Old 02-14-2012, 03:14 PM   #2
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: The best 4-link set up!?
This is the set up I plan on installing in the future when I get down to rebuilding my suspension
http://www.brotherstrucks.com/prodin...er=4BK87BC%2DB
Malo83 is offline   Reply With Quote
Old 02-14-2012, 04:57 PM   #3
Blacksunshine87
Thanks I'll keep that one in mind.
Old 02-14-2012, 11:20 PM   #4
SCOTI
SCOTI's Avatar
That set-up in the link will still require welding. For a 100% do it yourself, bolt-on kit for your 87 that's proven to work & engineered well, check out RideTechs 'AirBar' set-up. If you're not interested in utilizing air suspension (which is a great thing to have on the rear of a lowered truck IMO) you could look into their line of coil-overs....
http://www.ridetech.com/store/1973-1...ar-system.html
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-15-2012, 10:57 AM   #5
Blacksunshine87
I have seen that set up and i am leaning more towards it. It's just alOt of coin$$. Do you know anyone that uses the airbar set up?? Thanksfor your input btw.
Old 02-15-2012, 11:20 AM   #6
SCOTI
SCOTI's Avatar
It's more than other set-ups but is also something you can truly bolt-on w/common handtools in your driveway & has everything needed. RideTech is known for their quality products & frontline R&D efforts for improved handling.
Check out N2TRUX's 77 build. He had the rear air-over-leaf set-up & swapped to the rear AirBar.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-15-2012, 01:59 PM   #7
melks
melks's Avatar
Yea im going to agree with SCOTI, ride tech produces quality products...I dont have any experience with their equipment on square bodys, but i have been running their air bar along with other ride tech components on my s10 for almost 4 years now, they parts aint cheap but the results are well worth it.
1984 Chevrolet C10
melks is offline   Reply With Quote
Old 02-15-2012, 09:50 PM   #8
Blacksunshine87
Yeah I'll have to agree. After seeing the install on N2TRUX's I'm sold. Thanks SCOTI for bringing that to my attention. And everyone else's opinions! Thanks again!
Old 02-16-2012, 12:33 AM   #9
SCOTI
SCOTI's Avatar
There are a couple RideTech dealers on the board so reaching out to one of them might be a good thing should you need some installation support. If you opt to deal directly w/RideTech, check in w/Tony or Darren. I've dealt w/both of these guys more than once & they both are stand-up.
Be sure & ask specifics on the possibility of the coil-over swap if the bags aren't your cup o' tea. Let us know what you learn & post some pics of the build....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-16-2012, 09:29 AM   #10
Blacksunshine87
How exactly do I go about finding a dealer on this board? If you don't mind me asking ? Thanks! I'm in Maryland so closer would prob be better.
Old 02-16-2012, 09:45 AM   #11
SCOTI
SCOTI's Avatar
Look here for starters....
http://67-72chevytrucks.com/vboard/f...play.php?f=210
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-16-2012, 01:57 PM   #12
stroker87
I've been thinking of this also for my 87 short box
I have a built engine in the truck hoping to run 12's in engine and 11's on nitrous would these 4 links with bags handle HP around 400 @ the wheels? would this help traction or hurt it?
stroker87 is offline   Reply With Quote
Old 02-16-2012, 02:14 PM   #13
trixter99
I have no time for this
trixter99's Avatar
I wonder how big of a rear tire would fit with the brothers rear 4link.
1986 Chevy short box ( PROJECT )
1994 Chevy Blazer lifted 6"
2009 Gmc 2500 HD
1999 Hugger orange Camaro SS
2007 BMW X5 Sport
trixter99 is offline   Reply With Quote
Old 02-16-2012, 03:16 PM   #14
SCOTI
SCOTI's Avatar
That's part of the beauty w/bags... adjustability. But, check w/your local track to ensure the air suspension is not an issue. If so, coil-overs offer the adjustability needed for track tuning.
As far as the bolt-on 4-bar, for a serious track junky, I'd do a specific drag style weld-on kit if I felt my power level was ever going to get close to the 500rwhp mark. A street/strip vehicle would be just fine.
As always, it's best to verify any concerns directly w/the manufacturer to be 100% sure.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
