Old 02-14-2012, 05:18 PM   #1
crewcabshorty
crewcabshorty's Avatar
factory k-5 blazer buckets into crewcab ?
can anyone tell me if i can put a set of blazer buckets into my crewcab without modification ? i see that i need to unbolt the riser off of the bottom of the brackets , but i know crewcabs came with bucket seats , do they use the same brackets ?
crewcabshorty is offline   Reply With Quote
Old 02-14-2012, 05:51 PM   #2
ECU PIRATE
ECU PIRATE's Avatar
Re: factory k-5 blazer buckets into crewcab ?
What year Blazer buckets? You need to ditch the tracks and get some tracks from a 73-91 Burb along with inner mount for the bucket seats. I used 77' Blazer buckets and 80' Burb seat tracks in my 82.................
The Fleet........
68' Camaro - 1st car (restored & still have it)
09' VW Tiguan (Wife's Daily Driver)
14' VW Passat SE TSI (my personal)
14' Ford Edge Sport (Daily Work Vehicle)
73' SWB Stepside - 77K org. miles
74' LWB 454/TH400 - drive train transplant for my (Sold)
98' SWB C1500 W/T - shop truck (Sold)
90' GMC Sierra SLE short step - aka " Jezabelle " (Sold)
ECU PIRATE is offline   Reply With Quote
Old 02-14-2012, 06:05 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
might work
i changed put the jimmy base on the 89 burb seats
the steel bars are 16 inches wide
i drilled the holes and slid the bolts threw from the inside
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-15-2012, 09:59 PM   #4
crewcabshorty
thanks for the advice . the seats are from a1987 blazer , i want to put the factory center console in it also . does the suburban have a flat floor or a raised section for the seat ?
Old 02-15-2012, 10:19 PM   #5
80SPORT
80SPORT's Avatar
As far as I know the 73-91 crewcabs were never available with factory buckets ....but they were common in Suburbans.
You should be able to use the sub mounts.
80SPORT is offline   Reply With Quote
Old 02-16-2012, 07:35 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
this is the floor of my 88
i had to use the little brackets on the inside ,
mine came with custom seats i replaced to stock
John
