Old 02-14-2012, 06:12 PM   #1
72farmer
My 67 needs front disc brakes and have some questions.
I would like to keep the 6 lug bolt pattern.When you buy a 6 lug kit does it make your front tires wider apart?What about if you go to a 5 lug from a donor 71-71?Why can't you use everything from a 5 lug donor except find a 6 lug rotor?Reason i ask is i have a GMC donor but i would have to have 2 new 5 lug chrome ralleys and try to find them to match rear 6 lugs.
72farmer is offline   Reply With Quote
Old 02-14-2012, 06:37 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: My 67 needs front disc brakes and have some questions.
6-lug rotors can be added to your donor 71-72 front suspension.
They will be wider than the stock 6-lug drum suspension,... but no wider than the 5-lug suspension.
Aftermarket 6-lug rotors are just "blank" rotors drilled to the 6x5.5" bolt pattern.
Keith
Convert to disc brakes.
Old 02-14-2012, 06:37 PM   #3
lolife99
lolife99's Avatar
Read more here:
http://67-72chevytrucks.com/vboard/s...68&postcount=4
Keith
Old 02-14-2012, 09:58 PM   #4
72farmer
I think my plan now is to remove complete disc brake crossmember from my donor 72 GMC and put it in my 67 and then order aftermarket 6 lug rotors.I read somewhere that some rims would not fit on brake side when you converted.Here's pictures of mine made in 2006.Will they work?Thanls lowlife!!!
Old 02-14-2012, 10:01 PM   #5
lolife99
lolife99's Avatar
They will work fine to clear the disc brake calipers.
Keith
Old 02-15-2012, 09:45 PM   #6
1adriang
U can get six lug rotors and use the 71 setup I have a 68 I ordered 6 lug rotors from cpp if u were in Houston I still have them worked perfect
1adriang is offline   Reply With Quote
