Old 02-14-2012, 10:14 PM   #1
Stepper562
Stepper562's Avatar
Gas Tank Removal???
My driver side tank is never being used so I`d like to get rid of it. Currently its a 2 gas tank setup. Whats involved in making it work on only one tank which is the pessenger side tank, worth the headache???
I`ve dropped a couple of tanks before but never eliminated just one. Once I drop the driver side tank what do I need to change? What needs to be plugged up, rewired, removed etc. in order just to go off the pessenger side tank?
I just want to know if its worth the hassle, if not, I might as well remove them both and go with a blazer tank under the bed.
Thx in advance.
Stepper562 is offline   Reply With Quote
Old 02-14-2012, 11:43 PM   #2
rwhit57
rwhit57's Avatar
Re: Gas Tank Removal???
When I first got my truck it had both tanks. The crossover valve leaked badly and the right tank leaked a little too. I removed the valve and the wiring, and the rt. tank and just tied the lines straight to the lt. tank. It works fine but man do I miss having that extra tank on road trips.
"Whoever said money can't buy happiness has obviously never seen a speed shop!
rwhit57 is offline   Reply With Quote
Old 02-15-2012, 12:25 AM   #3
Stepper562
Stepper562's Avatar
So just get rid of the driver side tank, valve and run the line straight from the unit to the pump, correct???
No worries about long trips, I got my 2006 C10 (as I like to call it) for that. Just tired of seing the tank haning there for no friggin purpose.
Old 02-15-2012, 12:35 AM   #4
droppedgmc
Truck Enthusiast
droppedgmc's Avatar
correct
'85 swb
droppedgmc is offline   Reply With Quote
Old 02-15-2012, 01:15 AM   #5
rwhit57
rwhit57's Avatar
Yes, correct. I left the 3 lines in tact. one is supply, the other two are vents(I think), one of the vents goes to the pump and the other to the charcoal canister thingie(think you can do away with this one) . I removed everything else. One wire to sending unit. If I remember right I just tried a couple of wires to the sending unit till I saw it register on the gas gauge, then I knew I had the right wire. That is still wired to through the switch on the dash on mine I'm pretty sure.
Old 02-15-2012, 01:41 AM   #6
Stepper562
Stepper562's Avatar
So theres only one wire which supplies both sending units to the gauge???
Old 02-15-2012, 09:58 AM   #7
rwhit57
rwhit57's Avatar
No there's a right and left, I just chose to leave the switch. I think I just tried them to see which one worked the gauge from the position the switch was in. Make sure there's a good ground to the sending unit still. You'll see when you get into it, I think I had to splice the lines where the valve used to be. Pretty easy once you get started.
Old 02-15-2012, 10:02 AM   #8
Stepper562
Stepper562's Avatar
I'll give it a Shot this weekend...what's the worst that could happen correct??? Ground+12v+gas tank=Nice fireworks Haha.
