Old 02-14-2012, 10:55 PM   #1
blkcorvair
blkcorvair's Avatar
brake line frustration!!
I went to bleed the brakes tonight and have all sorts of problems. The PO put all new wheel cyl in. The bleeders are so close to the spindle I cant get a wrench on em, I have to use a socket on the front and they are 10mm??? did he buy some cheap wheel cyl?
Also have all new steel brake lines from In line tube. Almost every fitting was leaking. Ive had to (What I feel) is Over tighten every fitting to stop them all (Hopefully) In the meantime having a hell of a time trying to bleed these brakes!
blkcorvair is offline   Reply With Quote
Old 02-14-2012, 11:21 PM   #2
a2tripp
a2tripp's Avatar
Re: brake line frustration!!
sorry to hear, been there though. I absolutly hate brake lines and fittings and they hate me. Only advice I can give is to be patient, good luck
89 GMC V3500
Alaska members check in
a2tripp is offline   Reply With Quote
Old 02-14-2012, 11:24 PM   #3
CrewCab59
CrewCab59's Avatar
On the wheel cylinders , there a mix and match depending brand. The fittings leaks tighten Vs over tighten can spit / crack the flare and that's not good.Have you checked the flare to be flat, nicked,or not round ?
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 02-14-2012, 11:30 PM   #4
loudnlow72
loudnlow72's Avatar
while dealing with brake lines and fittings on a daily basis i have found that patience and a clean work environment really helps, be sure that all lines going in are not tweaked at all, otherwise the line will not be flush even though the fitting is tight. I agree that having a metric part on my AMERICAN truck is BULL! but there is not much we can do about that. I fought it all i could and the outcome is me still having 10mm bleeder valves
loudnlow72 is offline   Reply With Quote
Old 02-15-2012, 12:37 AM   #5
blkcorvair
blkcorvair's Avatar
I got it. A fresh look after a short break and I decided a different method of bleeded and some patience was in order. Seems good now. No more drips (fingers crossed) for now.
Old 02-15-2012, 10:23 AM   #6
Sammy
I replaced the wheel cyl on my project truck. One in the rear has a extended bleeder on it. I could get a pic if you want. Surely they sell them some place like NAPA.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 02-15-2012, 02:25 PM   #7
treveiger
treveiger's Avatar
Interested
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
