Power Window Question... stumped:/
My driver side window rolls down nice. But my passenger side rolls down SUPER slow, so slow that I think it might roll down a few inches and stop. What could be the problem with that passenger side window? Any suggestions would help.
-Samuel "Knowledge Is Power" |
Re: Power Window Question... stumped:/
the motor is wore out. need to replace it. replace both at the same time. im replacing mine. i just got some off of Ebay for $78 and on classic parts is 50 a piece. they are easy to replace.
Grease up your window tracks, check your window switch for a bad connection. It may be time to replace the window motor. Mine did the same thing on the pass side to where I had to physically go over and push up on the glass while I pressed the switch. Putting a new motor in it fixed the issue for me. I went ahead and did both cause when one thing goes bad its partner usually drops dead shortly after.
I've currently got the same problem on my 84, im going to check the connections and grease up the tracks to see if that solves it, if not i guess its time for some new window motors
1984 Chevrolet C10 |
Greasing the tracks will help ALOT. When I did mine, it didnt look like it had been done since it was manufactured. My motor was dying but it went up alot easier.
I agree with all above, but the connector end of the power window harness at the switch could also be defective and not making good contact. You can check by wiggling the harness/connector while trying to operate the window. If the motor cuts in and out as you move the connector, then you probably need a harness. You can search the online Delco catalog to find the correct connector/harness for your truck. Also, the plastic rollers that run in the regulator track can be frozen up from hardened grease or just plain wore out. I have not been able to find correct replacement rollers and they are swagged in, not bolted, so a new regulator would probably be in order for the best fix if you have that problem. For motors, I would check the online OEM vendors for GM or AC/Delco motors - I think they are sometimes less expensive than aftemarket. Try:
autopartstomorrow.com davesautoparts.com oehq.com oewarehouse.com rockauto.com Some of these vendors have free shipping. |
While you are in there replacing that stuff you may want to look into doing the window relay up grade. I was amazed what a diffrence it made. The cost was cheep to do. 4 realays and some wire.
I would try this before replacing the motor. The motors sometimes need a better ground. You can splice in to the ground wire that goes to the motor and ground the wire to the cab. Its worth a try and won't cost much.
http://67-72chevytrucks.com/vboard/s...d.php?t=355153 |
Is there a article on doing this? I ws thinking i might try relays on mine.
Just a note about doing this. The switch reverses the polarity on the two wires on the motor. If you ground one wire you will blow a fuse. Reversing the positive and negitive is how it makes the motor runs the other way.
Good point. Maybe running a separate ground wire from the cab to the window motor would be better.
#12 | |
#13 |
GM Addicted
also with a volt meter check what your power is going into the switch, then at the motor, you can find your power are grounds with a diagram or using a test light. Very easy to do and will narrow things down quickly. My brothers 89 had the same problem the power wire to the window had low voltage, taped it into a different power wire and work perfectly.
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
