Old 02-15-2012, 03:40 AM   #1
mmmBoost
CPP Poly Driveshaft Carrier... Thoughts?
Anyone have this on their truck? Looks good just want a buyers perspective and if there was any issues with sizes and etc?
Always remember those that had your back
Never forget those that turned it
Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt,
Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner
mmmBoost is offline   Reply With Quote
Old 02-15-2012, 11:03 AM   #2
67cheby
67cheby
67cheby's Avatar
Re: CPP Poly Driveshaft Carrier... Thoughts?
i am running it , i hope it works as good as it looks
67cheby is offline   Reply With Quote
Old 02-15-2012, 12:04 PM   #3
Lee H
Lee H's Avatar
I've had one from a different vendor for about 6 years. It will be the last carrier you'll need to buy.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have all original numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 02-15-2012, 01:48 PM   #4
67cheby
67cheby
67cheby's Avatar
SWEET, that is good to know !!
Old 02-15-2012, 02:01 PM   #5
mmmBoost
Awesome I'll be ordering one very soon then. Thanks for the input y'all
Old 02-15-2012, 03:19 PM   #6
hayhauler71
hayhauler71's Avatar
Had mine for about 5 years of abuse and works as hard as it looks with no problems
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 03-28-2012, 08:54 PM   #7
mmmBoost
Got my Carrier bearing the other day!!! Looks awesome, Much better than that P.O.S. that I used to have.
Old 03-30-2012, 03:47 PM   #8
mmmBoost
CPP Poly Carrier Bearing... Doesn't fit 3/4 ton!!! <<<HELP ME>>>
Well today I found out that the awesome looking Poly Carrier Bearing does not fit my 3/4 ton and they don't make one that does.
CPP is gonna have me return it and they're refunding me for the part.
So tonight after work is definitely time to drowned my sorrows LOL
Does anyone know where to get a Poly 3/4 ton carrier bearing? I thought about going with a 1 piece driveshaft but all the drive line places around here don't want to build one that long.
Old 03-30-2012, 05:22 PM   #9
Blackholebob
I just went through this with them.They don't say in they're catalog that this does not fit the 3/4 ton drive-shaft.I'm pretty sure that these are made by Inland Empire Drivelines.They do make the correct one for the 3/4 ton but it is not billet.It looks like the normal horseshoe one except it has the poly core instead of rubber.The drive-shaft diameter is approx. 1-3/8 so you have to have the bearing with the right inside dia.I have not purchased this yet so I cannot comment on it. Good luck. Bob
Blackholebob is offline   Reply With Quote
Old 03-30-2012, 06:47 PM   #10
SCOTI
SCOTI's Avatar
Seems like that's what is most important for a long life. The billet housing is just bling/added expense that no-one will ever see except maybe the muffler man or oil change guy....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 03-30-2012, 07:17 PM   #11
mmmBoost
My issue is the other poly one that looks like stock just doesn't seem stout enough. it still has the air gaps in the poly like stock. I love the rigidity of the CPP poly bearing. I'm gonna do some calling around with the local driveline shops and see if I can cross refference another poly bearing with a different year. If not I'm either gonna go 1 piece or have a custom carrier bearing/driveline made.
Old 04-01-2012, 11:29 PM   #12
mmmBoost
Any body have a cross reference for an awesome carrier bearing? I'm tired of replacing carriers.
Old 04-02-2012, 12:19 AM   #13
Constructor1
Forgive me everyone, but I have a dumb beginner question about these carriers, and the stock one for that matter. I have just glanced at mine and am looking at the CPP poly one pictured and am curious how to install. Does one of the yokes come off the drive line so that you can slip these on?
Constructor1 is offline   Reply With Quote
Old 04-02-2012, 12:23 AM   #14
longbed67
longbed67's Avatar
yep there is a bolt in the end that you take out pull it off put on the new yolk and bolt it back together...
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 04-02-2012, 03:43 PM   #15
mmmBoost
Mine slips apart no bolts. This is the driveshaft from my C20. My carrier bearing slides over the splines
Old 04-02-2012, 04:25 PM   #16
50bomb
50bomb's Avatar
I just buy the standard one for my 2 piece driveshaft. If you drive like an old grandpa like me than should be fine. Most drive reckless so they need something more stable.
50bomb is offline   Reply With Quote
Old 04-02-2012, 08:29 PM   #17
mmmBoost
Yeah that would be me. I can destroy a carrier in 6 months. I'm just tired of replacing it with the same everytime with the same outcome. I'm thinking about designing one myself.
