Old 02-15-2012, 02:24 PM   #1
chronos
Testing Power Windows / Locks
Hi all , have a set of doors with power windows and locks.
Is there a way to test them?
They are OFF the truck right now.
I currently have manuel windows / locks and bought these doors to eventually swap into mine.
chronos is offline   Reply With Quote
Old 02-15-2012, 03:00 PM   #2
54Caddy
GM Addicted
54Caddy's Avatar
Re: Testing Power Windows / Locks
would be very easy to do with a power probe. find some one that has one and you can test all functions of windows and locks
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 02-15-2012, 03:37 PM   #3
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Orange wire is hot all the time (so that's for your power locks)
Pink wire is hot when the iginition switch is on (so that is for your power windows)
Get a battery charger, put a fuse in the positive side, and hook it up to these wires and try the switches to see if they work.
Don't forget to ground the circuit too.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 02-15-2012, 10:04 PM   #4
ortega
All you need is the Orange and pink wire and ground. Put the Orange and pink together on the positive side of a battery or charger and the ground on the negative side, the window should go up or down. If you swap the positive and negative it will move the opposite way. You can do the same for the lock. I think the lock wires are brown and blue
ortega is offline   Reply With Quote
Old 03-05-2012, 08:49 PM   #5
chronos
Finally got around to testing this....Thanks for the help
Old 03-06-2012, 08:47 AM   #6
RandyP
Getting Old; Going Broke
RandyP's Avatar
Having a power probe is worth it's weight in gold sometimes. Super easy to work power windows with a door off the truck.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
