02-15-2012, 07:28 PM | #1 |
454 Oil Pressure
So my 350 had a nipple fitting into the block behind the intake manifold, which had a metal hose covered in rubber that led to a metal line through the fire wall. I thought this was a vaccum gauge and cut it(crap). So now my issue is how to set up oil pressure lines for mechanical oil pressure gauge in 76 GMC pick up? I don't know where to plug in at, how to run the line so it doesn't leak etc. Thanks in advance
1976 GMC SIERRA CLASSIC CAMPER SPECIAL! 454 BIG BLOCK BABY! |
02-15-2012, 10:20 PM | #2 |
No No
Re: 454 Oil Pressure
Well best thing to do is get a new oil line usually all the parts stores have them in either plastic or copper hose either works ok copper is better . The line kits sometimes have the fittings in them if not im sure you can piece everything togather or just buy a cheap gauge kit for $15 should have everything in it.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
02-16-2012, 12:16 AM | #3 |
Thanks! I didn't think about a kit, that's EXACTLY what I needed. You da man
02-16-2012, 12:19 AM | #4 |
Oil pressure line fitting will go right above the oil filter below head.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
