02-15-2012, 07:59 PM | #1 |
60/40 seat ideas
hello, I have a 1969 C/10. I removing the gas tank thats behind the seat, Would like to put a 60/40 seat in it, I have a 2 year old that likes to ride withe mommy and daddy. Anyone have any ideas, I don't mind having to drill new holes for the seat tracks. just don't want one that sits up to high and blocks the rear glass. Anyone have any pictures of there seats installed. I'd like to see them. Tell me what model there out of and the year. Thanks
Pete The worst I ever had was wonderful 69 SWB work in progress 97 Ranger 6in. lift on 35's 04 325i lady's ride |
02-16-2012, 12:19 AM | #2 |
Re: 60/40 seat ideas
I used a 60/40 from a late 80's, early 90's Chevy truck. I cut down the brackets a bit to get the back of the seat below the back window, but it really doesn't stick up much without cutting. The earlier seat don't have headrests and at some point they started putting headrests on the seats.....not a big deal if you are going to re-cover.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
02-16-2012, 02:23 AM | #3 |
Enjoying left field
Not a 60/40, but this is from an 88-98 truck, stock height. It comes up right above the bottom of the back window. It's a really comfortable height.
If you slide the seat forward a little on its mounts, the legs sit right behind the raised front mount pad. Last edited by woodwright; 02-16-2012 at 02:28 AM. |
02-16-2012, 08:18 AM | #4 |
Old member
Here is my 60/40 out of 89 Chevy truck.
02-16-2012, 08:43 AM | #5 |
Thanks guys for the pictures and ideas. I like the speakes and amp mounted in place of the gas tank. I'll be using that idea also. Thanks again for taking the time to answer,,, Already put a ad in the local trader for a 80-90 chevy truck seat
02-28-2012, 11:45 PM | #6 |
SactoJim, can you tell me where you got those seat covers. Or did you have them reupholestered?
03-01-2012, 11:22 PM | #7 |
with the thinner back on the seats ,do you feel it gave you anymore room?? i a big guy and thinking of puttiing a set of these in my 67, thanks,bruce
03-02-2012, 12:01 AM | #8 |
Enjoying left field
I deffinately noticed a difference. My original seat was also worn out, and shorter than it should be. Between that and the thinner back there is more leg room.
