02-15-2012, 11:29 PM | #1 |
5 lug pattern?
5X5 is that the standard distance btw the studs or lug pattern on 5 lug pattern 71-72? thanks
Jess
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
02-15-2012, 11:36 PM | #2 |
67-72 parts collector,…
Re: 5 lug pattern?
Lug pattern
02-15-2012, 11:46 PM | #3 |
Re: 5 lug pattern?
ok im dumb ....and have to ask do you know if the 5 lugs on 71-72 are all standard distance between the studs and is that what 5X5 means
thanks again jess
02-16-2012, 12:45 AM | #4 |
Re: 5 lug pattern?
Yes
Posted via Mobile Device |
02-16-2012, 12:48 AM | #5 |
Re: 5 lug pattern?
Thank you
QUOTE=mixermike;5191438]Yes Posted via Mobile Device[/QUOTE] Posted via Mobile Device
02-16-2012, 01:05 AM | #6 |
Re: 5 lug pattern?
Between the studs as in across from each other in a star pattern; not between each consecutive stud around the pattern perimeter.
02-16-2012, 09:33 AM | #7 |
Re: 5 lug pattern?
appreciate that, thank you
02-16-2012, 02:51 PM | #8 |
Never Ending Projects
Re: 5 lug pattern?
Typically when you see lug patterns listed, the first number is the number of studs. The second number is the diameter of the circle of the studs. This diameter is on the centerline of the studs themselves.
5 on 5 or 5x5 = 5 studs, 5" diameter circle. 6 on 5.5 or 6x5.5 = 6 studs, 5.5" diameter circle. Even number studs are easy to measure. Odd number studs require it be done a little different. Hopefully this chart will help some.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
02-16-2012, 03:11 PM | #9 | |
Re: 5 lug pattern?
you guys are the best thanks for everyone help 60 and still learnin
