New to this "online club"
I bought this '82 last October, new low dollar fun project. It needs new fenders for the bed .Any tips in general. Has manual disc/drum brakes and pads are good but starting to pull bad to the right. Thanks..
Re: New to this "online club"
Here are a couple photos of the truck when I bought it.
Chevys Kick A$$
Hey welcome to the best boards around from MT! Looks like a good start so far. Have fun with the new project
![]() Posted via Mobile Device
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
Just here to tinker
![]() Join Date: Jun 2008
Welcome from Victoria! Looks to be pretty straight! I didn't know you could still get manual brakes in the 80's trucks.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
Robert Olson Transport
![]() Join Date: Oct 2002
looks like a nice start to a decent project... keep us posted
Thanks to the replies, hope to have fun with it. I had the white/rusted rims sandblasted, then I painted with etching primer, Graphite Duplicolor wheel paint, and finally Duplicolor Clearcoat wheel paint. Then found the tires brand new tires on Craig's list $100 ea. Will keep u posted. Dave
I've never seen an 80's style GM truck with manual brakes. It's cool! Looks like a solid base to start with. I'd try to find a factory '82 grille for it and put the turn signals back in the bumper. That's my favorite 80's grille on these trucks. Nice ride!
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 ![]() |
Thanks for the grille info, I won't tell you about how several items were rigged to work on this truck and I stress "RIGGED". I knew someone did some rework to the grille. I have an '82 Chevy Truck brochure and it shows trucks with lights in 2 and 4 headlight setups, but all signals were in the bumper, painted them black for now. Daughter in college and original purchase price of $850 I could not pass up, but upgrades are as money allows. Dave
That was a great buy on that little truck. I have used the Duplicolor wheel paint and it's good stuff. That truck might have started out as a six cylinder truck, since it had manual brakes. In most cases the pulling to the right or left in the brakes will be a bad brake hose. They get frayed inside. You might start there to solve your brake problem. Good job!
"Whoever said money can't buy happiness has obviously never seen a speed shop! |
Brake pulls can also be caused by corrosion between the piston and the caliper bore.
In that case the deficient caliper is opposite direction of the pull; in other words, if it's pulling to the right then the left caliper/piston may be bunged up. I'd check that, too - K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Thanks, Yes it had a 350 SBC transplant before I bought it, my brother noticed the fan shroud or lack thereof where the inline six would have had a fan. They did an ok job but I need a new trans, the 700R4 has no reverse but gears 1-4 pull great., just have to back downhill only, ha ha.
#13 |
Thanks for brake reply, I had an idea caliper may be stuck LH side.
#14 |
Welcome neighbor!
Downers Grove member here! Looks like you got a solid truck to start with, since I'm local if I can help you out any way just send me a message Robert |
#15 |
Thanks for the welcome. I would not know where to start, the only item that may present an issue is the drivers door, badly rotted out and if you have any links on a used one keep me in mind. In time I plan to get cab corners and drivers rocker panel from LMC trucks. Then try to find a set of bed fenders, I like tha fact that they are 100% bolt on. I know doors can be bought through LMC, but the quality I would question. I will be at the Friday cruises there in DG. Until 2 years ago, I brought a 1995 Tbird that I had, sold it fall 2010 though. I nlike all classic cars or trucks, within reason. Dave
#16 |
78K & 79C Jimmys
hi,looks nice and solid
did a second take on the rims wondering if you just took paint off,but no....nice work
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#17 |
I seen some listed on CL might be some thing you want to look into?
power doors listed for $55 http://chicago.craigslist.org/nwc/pts/2825663824.html |
