I have two 1 Ton 4x4 SRW trucks and was wondering if there are any 1 Ton guys here?? I don't mean dually 1 Tons but the Single Rear Wheel kind?? I want to put the drive train under one of my K5 blazers to make an awesome bugout rig. I was wondering if Russ could respond because I was sure he did this???
Thanks guys and please send pictures if you have them. My trucks are in process right now with thre K5 Blazers also. ![]()
Re: Any SRW 1 Ton 4x4 guys here?? Pictures??
I've got an 83 2wd 1-ton. We use it to haul our camper. I'll get some pics tomorrow.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
Check the link in my sig
My un-named CCLB is a 1991 SRW 1 ton with a 6.2 diesel and 4L80E trans... ![]() Posted via Mobile Device
CHEVY ONLY
Next!
![]() Join Date: Jan 2003
CUCVs count of course!
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
I never see Russ on here any more.I see he's on CK5 a good bit. I had an '84 K/30 20 or so years ago and sure would like to have another. I have a set of axles handy. I'd like to do what my good friend did with an '85 K1500 High Sierra he bought that was pretty clean. He rebuilt a Dana60 and 14-bolt,put a locker in and disc brakes on the rear,2' lift,285/75-16s on 7" Ford steelies,TH400/NP205,and winch. Now all he needs are 3500 emblems. The only thing I'll do different is I have the 4L80E from my '91 Suburban.
I have an '85 Jimmy I put 3/4t axles in and it was a cinch. 1t axles would be just as easy. It worked out that I didn't have to touch the rear driveshaft because of the larger 14-bolt. I used a conversion u-joint at the rear. This is temporary with the plan being to shorten the Suburban driveshaft.
Got a 91 sub I'm putting a ton front in to match my rear which has 4:56 gears with a locker an I'm putting a 6.2 diesel in it an have 8ooolbs winch for front or rear six inch lift an 35s swampers
Posted via Mobile Device |
![]() Join Date: Dec 2011
1985 K30 SRW owner here in Jacksoville, FL.
I have a 1987 V30 SRW 4x4. It has the T.B.I. 7.4L, TH400, NP205, 4.10 gears, and true dual 3" exhaust with flowmasters. Its up to 77,235 original miles. The paint is crappy as usual for those years, but there is no rust what so ever on the truck. The interior is a 7.75 out of 10. .
1985 GMC K2500. 350/TH400/208. 4:10's. stock. 1987 Chevy V30. 454/TH400/205 4:10's. Stock SOLD. |
here are some pics.
more
interior
#13 |
more
#14 |
a few more
#15 |
Here's mine...
#16 |
I've been working on something similar, 1 ton running gear under a 76 blazer. Life has been getting in the way lately but I've been stocking up on parts.
70 stepside 76 blazer 86 Sierra Classic 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
#17 |
And some pics of my shot ass interior...
#18 |
#19 |
#20 |
Here is my latest one to pick up. I had the same idea on pulling axles like you and going under the K5. Did it a few years ago from a cucv and wheel it now.
#21 | |
#22 |
Big Gulps Huh? Whelp...
Mine is a dually now but withing the next week or so it will finally be SRW!
![]() Upholstery as it came to me with 52,300 original miles... ![]() ![]() Upholstery now! ![]() ![]() Carpet when delivered. ![]() Interior fully stripped, cleaned and Dynamat Exteeme Installed! ![]() ![]() ![]() ![]() Carpet and door sills now! ![]() ![]() ![]() Headliner and sun visors restored... ![]() Dash fully restored with ALL NOS PARTS! ![]() ![]() ![]() Tach cluster restored and installed! ![]() ![]() Now, WFO Concepts has the 14BFF right now do it can be gone through and an Auburn LS added and then we are good to go for the SRW swap. Then off for paint and body and then lift and tires/wheels! ![]() Posted via Mobile Device
"The Ghost II" - 1987 V30 CC, 14-BFF (2nd Design Heavy Ribbed HD) SRW Conversion, 454/4L80E/205, 6" Springs, 35" Toyo MT's on 17" Classic II's, Full Audio System, Lot of Other Goodies!
#23 | |
#24 |
Kid's Mechanic
Gentleman ,
This is not the classified section of the board . No more for sale stuff |
#25 |
here is mine
Clint Youse Paris, MO 1984 Chevrolet 3+3 K30 with Cummins 1966 IH Scout has been a work in progress for 16 yrs |
| Bookmarks |
