02-16-2012, 01:02 AM | #1 |
Shift Indicator 700r4
I know it has been asked before but i searched and couldn't find a good answer. I have a 69 NON tilt column that I will be putting a 700r4 into and would like the indicator to have OD or D with a circle around it or any 4 speed indicator for a non tilt column. Any help is appreciated.
Thanks, Logan
1969 C-10 LWB 388 SBC Vortec Heads 10:1 Lunati 60103 cam Weiand intake Quadrajet Carb 12 Bolt 3:73 posi 700r4 Hedman Headers 1998 Dodge Ram 1500 Reg. Cab Long Box 4X4 5.9L 183k miles 1956 Ford F-100 Longbed with Original 272 and 3OTT 1995 C1500 ECSB 6.5 Diesel 4l80e (Camper puller) 1997 Dodge 3/4 ECLB V10 (MPG machine) |
02-16-2012, 08:57 AM | #2 |
Re: Shift Indicator 700r4
Good question, may have to make your own?
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
02-16-2012, 08:57 AM | #3 |
LMC has one, but I'm sure that any of the board vendors have them too.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
02-16-2012, 10:00 AM | #4 |
Check out LMC truck's, part #38-4867
02-16-2012, 11:50 AM | #5 |
LMC's #38-4867 says it only works with the aftermarket columns. I have been looking for one of these for quite sometime and I haven't found one yet. You might be able to make LMC's part work, I also wondered about a mid 80's Van indicator, they also attach to the column.
Sean "If your gonna be dumb, you gotta be tough" 1960 Chevy Impala Sedan - my 25 year search is over!! 1969 C-10 longbed - Nice day DD 1970 Chevy Nova - Street and Strip Project 2002 Acura MDX my DD 2007 Honda Odssey - My Wife's "Mommy Van" |
02-16-2012, 05:28 PM | #6 |
I had the exact same question the other day on the blazer sub forum.
http://67-72chevytrucks.com/vboard/s...d.php?t=508908 the consensus is that this part does not exist for non-tilt. I actually ordered the LMC part for tilt columns hoping that i could "make" it work. it did not.
Andy 1972 Blazer 454 2004 Silverado Crew z71 |
