Question Gas Tank Relocation
OK Guys;
I know this topic has been done over and over but here I go, I got a gas tank out of a 78’ Blazer it measures 26”x26” my question is can the two frame rails in the back be removed? And relocated ?
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: Question Gas Tank Relocation
IMO, I would say no. you need those for structural integrity.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Never Ending Projects
The front one, don't move and make sure you leave it angled. It's that way on purpose. The rear one you can move back. I did that on mine but make sure you have clearance for the bumper bracket bolts, if you are running a back bumper.
Looking at the frame length, it looks like you are a short bed. You are likely going to run out of room to move the rear one. Long beds have the advantage there.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
60-66 Nut
![]() ![]() Join Date: Mar 2007
On your truck it would be better to move the front crossmember. Since you have leaf springs, that rear one needs to be there, but the forward one is typically there to support the panhard bar, which you don't have.
Guys;
Thanks so much for the info, Chevy Mike was right no matter what I move this gas tank is to Big I decided to go with a BD Racing 20 Gallon Custom Aluminum Fuel Cell I found on EBay for $239. its 24x20 I'm sure I'll still have to move the one of the frame rails, but only maybe 3", as Captain fab suggested moving the front rail would be better, But will this reduce the integrity of the frame strength
60-66 Nut
As long as you just move that forward crossmember, you will be fine. If you were to just remove it, that could cause an issue.
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Thanks for Captain seeing it was a leaf spring truck so knowing which crossmember could be moved.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
