Old 02-16-2012, 05:55 PM   #1
Hazieview
Building Dreams out of Dimes!
Headlights??? Which ones should I go with? There are so many! Halos, HID, Projector??
So I need some headlights.....
I am willing to spend a little extra money if it is worth doing. I have an '81 Chevy with 2 square headlights on each side.
I want to be able to see better than just the yellow haze that my old headlights gave off but I DONT want to blind people. I also DONT want purple, green, blue, or any other color. Plain WHITE will do just fine.
What do you guys recommend?
I was thinking the LMC heavy duty harness with halogen bulbs and bran new head light lenses.
However if I can get better lights for a little more cost I would prefer that. Any advice you guys can give would be great.
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
Old 02-16-2012, 05:59 PM   #2
JRANGER
JRANGER's Avatar
Re: Headlights??? Which ones should I go with? There are so many! Halos, HID, Project
I bought my lens and h4 from Amazon but I would def recommend going with the Relax Harness to make it brighter
JRANGER is offline   Reply With Quote
Old 02-16-2012, 06:42 PM   #3
wilkin250r
wilkin250r's Avatar
I don't know what options are out there for squarebodies, most of my lighting experience is with motorcycles.
But I CAN tell you that halogen headlights are indeed brighter than regular incandescent bulbs, which is why the automotive world has pretty much moved to them universally. HID lighting is brighter still, and is my personal choice for my ATV due to the greater output and less energy consumption. However, energy consumption isn't a major concern on a truck, and some people consider HID lighting to be too bright.
wilkin250r is offline   Reply With Quote
Old 02-16-2012, 06:56 PM   #4
Evil Trailblazer SS
Big Gulps Huh? Whelp...
Evil Trailblazer SS's Avatar
Hella H4 Conversion Kit with halogen bulbs and headlight relay harness...
- End of story -
"The Ghost II" - 1987 V30 CC, 14-BFF (2nd Design Heavy Ribbed HD) SRW Conversion, 454/4L80E/205, 6" Springs, 35" Toyo MT's on 17" Classic II's, Full Audio System, Lot of Other Goodies!
Evil Trailblazer SS is offline   Reply With Quote
Old 02-16-2012, 07:18 PM   #5
BMERDOC
BMERDOC's Avatar
Going under the assumption you are on a budget. Do your own relay upgrade, get some Sylvania Silverstars, clean your grounds and have your headlight aiming checked. How old are your current lights? They do dim over time. I dont trust the relay kits out there and the can be kinda ugly.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 02-16-2012, 07:24 PM   #6
bucannon
Salty Sailor
bucannon's Avatar
the only bad thing ive heard about using the relay harness with halogen lights is the increased heat causes the glass lenses to crack. that is one advantage of HIDs since they dont produce as much heat, and if you get about 4000k they will produce a nice white light and aimed properly will not blind people
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 02-16-2012, 07:35 PM   #7
VH Coachworks
VH Coachworks's Avatar
Your for surely going to want to upgrade your OE headlamp harness to begin with. That alone will make a pretty large upgrade in light output. I would also recommend a halogen upgrade for the lighting, and not the low end halogens. Sylvania Silverstar Ultra's are the king of Halogens in my personal experience, they will be leaps and bounds ahead of any incandesant bulb out there. However, a set of 4300K HID's will still be MUCH whiter and have MUCH more light output when aimed correctly and installed in an appropriate housing. Once you have driven a vehicle with a set of properly installed HID's, you will never go back to Halogens! If you want the best possible light output, look into retrofitting a OE style projector into a set of clear headlight housings and then install HID's. We will have an article up within the next month or so on retro-fitting projectors.
Take a look at this article we wrote, it will go a little more in-depth on the topic: http://67-72chevytrucks.com/vboard/s...d.php?t=491436
VH Coachworks is offline   Reply With Quote
Old 02-16-2012, 08:08 PM   #8
Evil Trailblazer SS
A 4300k will yield a slightly yellow but mainly white light output and a 5000k will be a pure white with no blue hues at all...the choice in HID should be made lightly, cheap HIDs are crap and the placement of the bulb's "arc chamber" is critical to reducing glare in a non-projector housing.
Old 02-16-2012, 08:33 PM   #9
Stew_Magoo
Before opening your wallet and wasting money, spend some time getting learned.
http://www.danielsternlighting.com/tech/tech.html
Stew_Magoo is offline   Reply With Quote
Old 02-16-2012, 11:09 PM   #10
stroker87
I agree with the 5k hid bulbs they give off more of a pure white then the 4300k do I only run the 5k in my cars, the 95 gmc i just bought does not have HID's and I hate it can see a thing at night but i'll be fixing that shortly
stroker87 is offline   Reply With Quote
Old 02-16-2012, 11:39 PM   #11
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
I have these from truck-lite. They are the same as the LMC "EUROPEAN STYLE" in my 90 suburban with single headlight setup. I got the 5000 kelvin white light as well for a truer white light as opposed to the other "colors" available.
They use the 9003 (H4) style bulb which I swapped out for the H.I.D. kit I got from www.v-leds.com
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 02-17-2012, 02:32 AM   #12
Evil Trailblazer SS
V-LEDs makes good middle of the row kits, but I have had some of their stuff fail recently, but they always sand behind there product!
I went the www.theretrofitsource.com and their kits are more expensive, but include full wiring harness/relay upgrade and they seem to be built to a higher quality standard, no report of long term reliability from me yet though!
Old 02-17-2012, 02:44 AM   #13
6lcummins
I agree, I went 6k HID BiXenon kit on the 98.5 Dodge and I was severely impressed. Spent $80 shipped on the kit and it came from China where ALL HID parts are manufactured.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
Old 02-17-2012, 12:01 PM   #14
Evil Trailblazer SS
That statement could not be farther from the truth...but I will digress!
Old 02-17-2012, 01:59 PM   #15
INSIDIOUS '86
INSIDIOUS '86's Avatar
Go to ddm tuning. 15 dollars a kit there with a lifetime warrantee. Mines been going strong for a couple months!
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 02-17-2012, 03:38 PM   #16
Evil Trailblazer SS
Just wait till one of them fails...DDM has a very sketchy customer service history and it's a crap shoot whether you get taken care of properly or shoved on the back burner for warranty replacements...
Old 02-17-2012, 08:51 PM   #17
6lcummins
Then is it Japan?
"STOCK"
ASSEMBLY THREAD
Old 02-17-2012, 09:27 PM   #18
Evil Trailblazer SS
Wink Re: Headlights??? Which ones should I go with? There are so many! Halos, HID, Project
Then is it Japan?
No, you would have been correct in saying MOST HIDs (especially the crappy ones, like DDM) are made in China, but the good stuff is made in Japan, Germany, etc.
McCulloch, Hella, Philips, PIAA, Helios, Pro Lumen, Maruta (M-Tec) and even Morimoto are the high end names in the HID world and you really do get what you pay for. Not saying all cheap HIDs suck, but it's a total crap shoot, one ballast may last 5 years and the next one may only last 3 months. Quality comes with consistency and both of those come for a price...Expensive HIDs are not for everyone and not everyone can justify the cost, but I don't mind paying for peace of mind...
Old 02-17-2012, 10:40 PM   #19
6lcummins
Ok, then I was wrong, the VVME kit I got says they are HELLA ballasts. We shall see and I'll see if i have to use the 2 yr warranty...
"STOCK"
ASSEMBLY THREAD
Old 02-17-2012, 11:56 PM   #20
Squareforceone
Squareforceone's Avatar
Sylvanina halogen bulbs
Rust is better than rice.
Squareforceone is offline   Reply With Quote
Old 02-18-2012, 12:47 AM   #21
All Biz
Blue Lights
All Biz is offline   Reply With Quote
Old 02-18-2012, 12:58 AM   #22
All Biz
Blue lights
Old 02-18-2012, 09:03 PM   #23
dale3goodwrench
I am getting ready to change my headlights to halogen also. Anybody have a link to where I can buy a relay kit ?
dale3goodwrench is offline   Reply With Quote
Old 02-18-2012, 10:12 PM   #24
flamingbig10
6.0 powered square
flamingbig10's Avatar
I made my own two 30 amp relays, two relay connectors, one 30 amp circuit breaker, and a assortment of wire
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 02-20-2012, 01:20 AM   #25
Hazieview
Are HIDs setups way more expensive than Halogen setups.
I'm still confused on what all I need for a good HID setup.
SB400 350th
