Old 02-16-2012, 09:00 PM   #1
Gyawo
Exclamation Drivetrain swap
I am looking to swap the front and rear diffs and the transmission from a 1980 SWB chev into a 1986 chev K5. What sort of headaches am I going to have? The K5 is an auto, so I know there is going to be a fair bit of choppy choppy with my floor, what I am most interested in are how easy the diffs will be to switch over.
Gyawo is offline   Reply With Quote
Old 02-16-2012, 11:14 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: Drivetrain swap
The axles are a direct swap. The only problem you may have is the rear shaft.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 02-16-2012, 11:16 PM   #3
Gyawo
Re: Drivetrain swap
I won't have an issue with widths and leaf spring mounts? I can get the shaft shortened/extended easily at one of the driveline shops in town.
Old 02-16-2012, 11:23 PM   #4
ghettoluxury
Re: Drivetrain swap
No problems with spring pads direct swap.
Old 02-17-2012, 09:47 AM   #5
Gyawo
Re: Drivetrain swap
Thank you.
