Old 04-30-2003, 09:15 PM   #1
Twilightoptics
S10 V6 Transmission on V8
I know it's not recommended to use a V6 trans on a V8, however, I have nothing else to use right now and this truck needs to be on the road again.
I am putting the 305 out of my old Camaro, and putting it into my '84 S10 that came with a 2.8L engine, 5speed manual.
Is the input shaft the same as on a V6 camaro? If so I know it will work with a V8. I have the V8 bellhousing, and after getting things apart it looks like I'll need a different clutch fork/slave cylinder. I think it's the slave anyway, the one that pushes on the fork.
Any info would be awesome! Thanks
-Paul
Twilightoptics is offline   Reply With Quote
Old 04-30-2003, 11:27 PM   #2
Ol' Grey
A work in progress
Ol' Grey's Avatar
Is it a Borg-Warner T-5? I have a copy of the specs for it as well as the T-5 that goes in the Camaro.
Marc Cook
1986 Chevy Silverado C-10 LWB
Gunmetal Grey Metallic
5.0L HO, 700-R4, '73 12-bolt rear
Long tube headers, 2.5" dual exhaust dumped before the axle.
1988 GMC Sierra SLE 4WD
5.7L, 700-R4, stock everything
6000LB winch
Ol' Grey is offline   Reply With Quote
Old 04-30-2003, 11:42 PM   #3
Twilightoptics
Any info is great. From what I've gathered so far... I need to use the Camaro Slave Cylinder, and modify it to fit the threaded s10 clutch line.... and need to use the camaro clutch fork, etc.
Also I think I have to grind the input shaft down aswell as the bearing sleave?
Old 05-01-2003, 09:30 AM   #4
Ol' Grey
A work in progress
Ol' Grey's Avatar
I found the newest literature from the company that bought out Tremec who bought out Borg-Warner.
Here's a service manual:
http://www.ttcautomotive.com/English...-0510-0199.pdf
Here are some specs:
http://www.ttcautomotive.com/English...nsed_Specs.pdf
Marc Cook
6000LB winch
