02-16-2012, 11:08 PM | #1 |
Always a work in progress
Power steering pump question
The power steering pump from the 2004 lq4 has 2 return lines and 1 feed line, what do I do with the extra return line?
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
02-16-2012, 11:33 PM | #2 |
Has more rust than truck...
Re: Power steering pump question
Cap off one return...or run hydroboost brakes
02-17-2012, 08:48 AM | #3 |
Ok, so I don't have to get a different pump, that is good news. How should I cap it off? Is there any kind of pressure on the returns?
02-17-2012, 01:14 PM | #4 |
meowMEOWmeowMEOW
a bit but not much. I just stuck a stainless bolt in the end, I think it was a 12 or 14mm I had laying around. Stuck a hose clamp around it and it hasn't moved anywhere in the past 5000mi or so.
02-17-2012, 01:50 PM | #5 |
Ok cool.
02-17-2012, 02:50 PM | #6 | |
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
02-17-2012, 07:02 PM | #7 |
I was thinking of just putting a short piece of hose on it with a bolt or rod of some sort in it and then clamp it down.
02-17-2012, 08:32 PM | #8 |
meowMEOWmeowMEOW
Mine had a stub of rubber tubing on it, I stuck the bolt in that. It wasn't the bare metal.
02-18-2012, 12:51 PM | #9 |
JRods Garage
mmmm, id be running hydraboost!
Orange Julius-My dropmember'd, LS'd, SWB street machine... |
02-18-2012, 01:48 PM | #10 |
meowMEOWmeowMEOW
Oh it won't be blocked for ever....need to figure out my compact rear disc brake setup and then the hydro will be backing that and the wilwoods up front.
02-21-2012, 09:57 PM | #11 |
GM ONLY BABY!!!
tapped mine with a tap and threaded in a bolt with some thread sealer on it.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
02-22-2012, 10:00 AM | #12 |
I T'd mine together to a remote reseviour (sp).
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
02-23-2012, 06:51 AM | #13 |
Collector of Projects
Wanna trade?... I have one from a 2005 LQ9 with only one return. It only has 50k miles and I'll post some pics...
