Old 02-16-2012, 11:23 PM   #1
Project77
77 chevy silverado lwb shackle question?
okay tonight im planning on putting the 2 inch shackles on the rear leaf springs will i need to cut my bed frame at all? can you give me step by step instructions on how to do this or a video which ever you have thank you
Project77 is offline   Reply With Quote
Old 02-17-2012, 01:19 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 77 chevy silverado lwb shackle question?
You will need to look under there yourself. There were two different lengths of leaf springs combined with SWB, LWB, step or fleet. Since you have a LWB Step, it would be really hard to be sure if the crossbrace will be in the way or not.
The easiest way to cut the brace if needed is to unbolt the stock shackle and remove it. With that out of the way, lower the spring down so you have enough room to work. Use a plasma cutter if available, or a cut off wheel if not.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
