Old 04-30-2003, 09:56 PM   #1
1972chevy4x4
1972chevy4x4's Avatar
corp 12 rear: how much play is to much?
I have a gm corp 12 rear end in my 1972 k10 and have about 1/2 to 3/4 of an inch play when I grab and turn the yoke. My question is how much play is to much? I have be told 1/8th inch is correct and as high as 1 inch correct. Thanks for any info
1972 chevy k10 4x4 longbed 4-inch lift, 3.73 front/rears, frame off nearly complete
1972 chevy k10 4x4 longbed parts truck, known as the "ugly green machine"
1990 GMC 3/4 shortbed ext cab
Always in need of 67-72 parts in central ks.
1972chevy4x4 is offline   Reply With Quote
Old 05-09-2003, 12:12 AM   #2
86k10
You're probably getting some wear on your axle splines and side gears, that's why you have so much, but move it back and forth real slowly and you can tell where your ring and pinion backlash is, and then anything beyond that is wear on other components. That's actually quite a lot of play unless you have a genuine detroit locker, then it's normal. but if you have a normal open diff, it's just showing it's age.
98 Neon
97 Grand Prix GT
02 Grand Prix 40th Anniv.
86 GMC 5.0
77 Olds 98 6.6
REAL AMERICANS, DRIVE AMERICAN
86k10 is offline   Reply With Quote
