02-18-2012, 01:26 AM | #1 |
Wiring Harness
Who are you guys using for wiring harnesses?
Right now I'm looking at these two companies. Has anyone had experience with them? My engine will have its own harness so I'm not sure how many circuits I will need for the rest of the truck. I would rather have more and nmot need them than the other way around. http://stores.ez2wire.com/-strse-Kwi...Categories.bok I've heard good things about Rebel Wire. They also make a kit that will put the fuse panel behind my seat. http://rebelwire.com/ Thanks for any input. Kim |
02-18-2012, 01:59 AM | #2 |
Re: Wiring Harness
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
02-18-2012, 05:28 AM | #3 |
Re: Wiring Harness
hi Kim I bought a ezwire harness not fully fitted yet but pleased with quality for the money. Have heard good things about the rebel kits but my local rodshop in the uk now sells the ez instead, probably as were all cheapskates here in the uk. Hope the new engine is working out looking forward to seeing a update on your build thread I really wanted a big block too but some things are not meant to be for time being at least. George
02-18-2012, 09:08 AM | #4 |
Re: Wiring Harness
American Auto Wire 21 GM color code
02-18-2012, 09:28 AM | #5 |
Re: Wiring Harness
I used a American Autowire Highway 22. Very nice kit. They also offer add on acceseries for an afortable cost.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
02-18-2012, 11:37 AM | #6 | |
Re: Wiring Harness
Thanks for all the input guys, I appreciate it.
OrrieG I read that thread also and was just trying to get as much info as possible. Kim Quote:
02-18-2012, 01:13 PM | #7 | |
vintage car junkie
Re: Wiring Harness
1950 chevy truck, s10 swap, bagged, v8, 18s My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761 |
02-18-2012, 01:29 PM | #8 |
Re: Wiring Harness
I used the EZ Wiring harness, 21 circuit. strait from EZ in an ebay auction, and it was less than $200 shipped. great quality, vague simple instructions but I emailed them years later and they were quick to help. (and they are still around so that was a great sign!) wires labeled every foot or so, great simple kit. Factory GM Steering column turn signal/ignition wiring.
they also have a list of things to check out for while installing... I recommend. here is a different auction, but same kit 21 Circuit EZ Wiring Harness on eBay |
04-04-2012, 04:05 PM | #9 |
Re: Wiring Harness
Just thought I would post what I ended up getting.
AAW Highway series 22. Kim |
04-04-2012, 05:21 PM | #10 |
Re: Wiring Harness
now that clean area under your dash will fill up
make lots of notes when you do something not on the instruction. drawings of relays with wire numbers and color help when you get down the road. also any switches you add make a note. i've had to refer back to my drawings a couple of times, save time and your sanity. when i did the 11 power tour i took just a handful of tools, plus my multimeter and all my electrical dwgs just in case under my dash is pretty clean, but in the console where all the relays went is a cluster f**k
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
04-04-2012, 05:24 PM | #11 |
Re: Wiring Harness
I'm going to try and get it behind the seat. If that doesn't work then it will be in the console.
Kim |
04-05-2012, 01:29 AM | #12 |
Re: Wiring Harness
I know you already bought yours, put i am using the Painless wiring 21 circuit kit. Great quality and I knew VERY LITTLE about wiring when I installed it years back and cam out great. Had good instructions and all the connectors and terminals and wire ties and clamps.
Every wire is labeled along the wire and I'm ready for all future creature comforts for a/c to power windows/locks to cruise when i get them. Had enough length wire to run and hide every where Good luck with yours. Looking forward to how it comes out. I'm looking for a new one for my dads 71 Chevy p/u and seeing what others been using/like. |
04-05-2012, 08:56 AM | #13 | |
Re: Wiring Harness
I found this one for $398.00 and it has everything I need plus some. The wires are all printed with the circuits and it has extra conectors. I won't know how good the instructions are until I start on it though. Kim |
04-05-2012, 12:23 PM | #14 |
Re: Wiring Harness
I bought a painless kit shortly after I bought my truck. Hopefully I will be installing it soon. I bought it from Yogis and they were having a sale on it plus Painless was offering a $100 rebate at the time. If I remember right I ended up paying a little over $200 for it.
55 2nd series Chevy Pickup 2019 Chevy Equinox(Daily driver) 2011 Chevy Malibu (Wife's car) MSRA Member I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose. -George Carlin |
04-06-2012, 12:18 AM | #15 | |
Re: Wiring Harness
But like you, I am also looking for a more inexpensive harness from our current vendors for my dad's truck |
04-06-2012, 12:52 AM | #16 |
Re: Wiring Harness
kim
i am sure w/ your ingenuity it will turn out just fine - all you work is top notch sir ! |
04-06-2012, 12:54 AM | #17 |
Re: Wiring Harness
also - i am useing a AAW kit 21 circuit - to me everything is layed out v v well and info is in COLOR !!!!!!!!!!
Good luck and i think you will like your harness |
04-06-2012, 03:03 AM | #18 |
Re: Wiring Harness
http://www.ebay.com/itm/UNIVERSAL-WI...sories&vxp=mtr American made and seems to have a great rep.
04-06-2012, 01:58 PM | #19 |
Re: Wiring Harness
I went the simple route and used a 1978 Chevy pickup harness that was in one of my parts bins. Tons of circuits, everything was the right length and easy to install. I am a big recycler of parts and hate spending money to make myself more work..
Posted via Mobile Device |
04-13-2012, 04:46 AM | #20 | |
Re: Wiring Harness
