Old 02-18-2012, 01:32 AM   #1
Car'n'Guitars
Car'n'Guitars's Avatar
General Maintence
What all should be replaced since I am replacing spark plugs what else should be replaced along with them? Also is there any special fuel filter that has to go in a quadrajet carb? And does anyone know where to get the fuel inlet housing for the fuel filter on a quadrajet?
1985 Chevrolet K10 Custom Deluxe---SOLD
1997 Ram 2500 5.9 Cummins
1985 Chevrolet Camaro Z28
1987 Chevrolet K10 Silverado
"The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257
Car'n'Guitars is offline   Reply With Quote
Old 02-18-2012, 01:49 AM   #2
Squareforceone
Squareforceone's Avatar
Re: General Maintence
are we just talking under the hood? Plugs, wires, fuel and air filters, oil change. Not under the hood bulbs... like all of mine took a crap at once last week tail lights dome light etc..
Rust is better than rice.
Squareforceone is offline   Reply With Quote
Old 02-18-2012, 01:53 AM   #3
Car'n'Guitars
Just under the hood for now. Also does anyone know how to change the transmission dipstick seal?
Old 02-18-2012, 02:06 AM   #4
Car'n'Guitars
Also what is the size of the fuel line that runs from the fuel pump to the carburetor?
Old 02-18-2012, 07:48 AM   #5
Goldfinger
Goldfinger's Avatar
Don't forget to grease you zerks. they kind of look like little nipples they will be near your bushings. I believe its recommended every 3 months 30k miles. cap and rotor as well.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 02-18-2012, 09:32 AM   #6
jitteryguy
GoatLube Experss
jitteryguy's Avatar
there's a bolt in the back of the cylinder head hold'n the dip stick, remove it and the stick will pull up out of the trans. the seal is just a rubber boot, it will very likely be cook'd to the trans and you'll have to dig it out, lube the new one and push into the trans then slide the dip stick tube back into the seal.
also check all the hose's, valve cover bolts vacume line's, ect.......
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 02-18-2012, 09:36 AM   #7
donut
donut's Avatar
dipstick seal- where tube meets the pan?
clean area where tube meets pan (don't want crud falling in) remove tube, should be a slip fit. May be attached at the bell-housing, unless your truck has been previously molested.
Crawl underneath, reach up and pull seal from trans replace w/new seal, re-install.
Where big bolt is sticking up is your seal.
IIRC fuel line is 5/16's
Fuel housing for a q-jet, Used to be you could get them at any parts store, some hanging in the 'help" section, but I haven't shopped for one in a while, ask at the counter. Why do you need the housing? Yours stripped out?
Filter- there is a small filter that goes into the inlet housing. Personally I prefer an inline filter before the carb. Easier to change, esp where your already shopping for a fuel inlet.
Under hood, first thing I'd do is get some degreaser and a hose and clean. Nicer to work on and easier to see problems.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 02-18-2012, 11:12 AM   #8
C-10 simplex
You have to be careful not to strip it---the inlet housing/nut. If it's the nut that screws into the carb/housing then you could likely find one at the local salvage yard. There are places where you can find them new as well but i don't have the info off the top right now.
a) If it's a rebuilt carb from a parts store, then the inlet nut is most likely wrong!
If it's the actual housing in the carb, then this is more involved.
C-10 simplex is offline   Reply With Quote
Old 02-18-2012, 11:15 AM   #9
Car'n'Guitars
Yeah my housing is stripped out. Thanks for the picture that helped me a lot. Yeah definately needs the engine cleaned. And thanks to everyone that put information into this.
Old 02-18-2012, 12:29 PM   #10
Car'n'Guitars
How do you get the fuel line from the fuel pump to carburetor off?
Old 02-18-2012, 03:03 PM   #11
Car'n'Guitars
Well I managed to save the fuel inlet housing, but still no luck on the line from the fuel pump to carb any advice?
Old 02-18-2012, 03:11 PM   #12
donut
donut's Avatar
Off of which end? It should be attached to the fuel inlet and pump the same way.
That's another reason why I use the in-line filter. Remove the inline filter and it gives you a spot to drop a box wrench down the line. A flair wrench is recommended, but if I can get a box wrench on it...
Old 02-18-2012, 03:15 PM   #13
Car'n'Guitars
On the fuel pump end. I am using line wrench and it almost seems like the bolt part is stuck or stripped into the pump. Also do you know if this will work or a line replacement?
http://www.autozone.com/autozone/acc...er=216473_0_0_
Old 02-18-2012, 03:31 PM   #14
1LowToy
You need a flare-nut wrench or you will almost for sure round off the nut with an open end wrench
1LowToy is offline   Reply With Quote
Old 02-18-2012, 03:32 PM   #15
Car'n'Guitars
Yeah thats what im using but I call them line wrenches.
Old 02-18-2012, 05:53 PM   #16
mrhino
auto zone sell a repair fitting here http://www.autozone.com/autozone/acc...questid=773415
iv never used one but they do make em. your line will be tight. years of rust and corrision. it is junk dont worry about damaging it. your gonna replace it any how. spray a little penetrating oil on there, if that dont work, heat it with a torch. (just kidding)
one trick is to get the wrench on there good and then smack it with a hammer, the wrench that is. the quick sharp blow will most likly break it loose. same theory as a impact gun. if all else fails cut the line and get it with a ratchet and socket.
mrhino is offline   Reply With Quote
Old 02-18-2012, 06:22 PM   #17
donut
donut's Avatar
Being from New England (where I had to replace brake hard lines often) I'd use steel brake line for a new fuel supply, just bend new and re install. If your gas line fittings are to boogered up, you may have to pull the fuel pump to get better access to the fitting.
(ok, maybe not have to, but sometimes it's easier to approach from a different tac)
Something else to consider while your there. How old is the fuel pump? Sometimes it's cheaper to spend a few bucks than deal with the aggravation. Mech. pumps are fairly cheap.
Years ago I learned this dealing with brake bleeder screws, now if they're frozen/stripped, I just junk the wheel cylinder.
Old 02-18-2012, 06:53 PM   #18
Car'n'Guitars
That's what I'll be doing went and bought spark plugs and a fuel pump for my truck. Will get new lines tomorrow. Thanks for all the input everyone.
Old 02-19-2012, 07:13 PM   #19
Car'n'Guitars
Got the spark plugs in but I broke one so I had to get another one. Put the fuel pump on with no problems. And put the fuel filter in the carb. But still need to get a fuel line from the fuel pump to the carb. Went to advanced auto and one guy told me they could bend a fuel line to be a replica of my old fuel line. Came back with my fuel line the next day and this guy tells me they can't do it. So I will be figuring out what my next step is.
Old 02-20-2012, 01:47 AM   #20
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
Try this company:
http://www.inlinetube.com/
My line from the fuel pump to the carb went south on me and got a perfect replacement from them.
1978 Chevy SWB C-10 2WD 454/400
78 Big10 454 is offline   Reply With Quote
Old 02-20-2012, 09:19 AM   #21
donut
donut's Avatar
You can order a replacement (like above) or if your somewhat handy, bend up your own.
Fuel lines really only need to go from point A to point B. (safely, don't lay it across headers, let it rub on the valve cover, etc) What I do is measure what I need for length, run down to the parts store, grab a straight length of brake line that is made up with the ends, bend away. You may have to get a bender, iirc off of the pump is a 90, little difficult to bend without kinking and no bender. Not really difficult, but can be frustrating. (esp if your looking for a perfect factory look).
Old 02-20-2012, 11:16 AM   #22
Car'n'Guitars
Originally Posted by 78 Big10 454 View Post
Try this company:
And these cost cost more than I want to spend right now. Thanks anyway.
Not looking for exact factory just a running truck. That is what I was going to do but I don't have any tools to bend it like I need.
Old 02-20-2012, 04:00 PM   #23
mrhino
hands are all you need
Old 02-20-2012, 04:05 PM   #24
donut
donut's Avatar
Most of your big parts houses do stock in-expensive benders that'll do the job.
If you don't mind investing in tools, I liked my set of Ridgid benders (sold them) but much like guys that use Snap-On etc. I needed the benders for work.
I personally haven't had any luck with the "spring" benders that are sold, had one and chucked it into the woods, imo best place for it.
Even if I can get the bend close, I can usually finish it off by hand, forming it around something close to the bend, like a piece of pipe, trailer ball, just look around.
Sometime soon I have to re-do mine also. PO, rather than bend the tubing, replaced the 90 at the pump with a piece of rubber fuel line. Clamped to a small piece of tubing off of the pump and the rest of the factory tubing over the valve cover..
Old 02-20-2012, 04:09 PM   #25
Car'n'Guitars
What are the chances of damaging the tubing in the process?
