Old 02-18-2012, 04:39 PM   #1
vegas80step
vegas80step's Avatar
swap to pwer windows, need help wiring switch
I switched over to the OPP window and added power. The power motor works fine. (when running it off a battery charger)
I bought new switched and can't for the life of me figure out how to wire them.
this is the back of the driver side:
(the front is the normal two button square chrome switch)
let's call them 1-4 on top (left to right)
5 bottom left and 6 bottom right..
Any one know hoe to wire this?
Number 3 is a little larger and a little longer. I think this is positive.
I assume the other go to the two wires going to the power motor and some have to be negative. just not sure what goes where.
I also have the passenger door to do. the button looks a little different.
I'll post a picture of that one also. or maybe if some one can help with this side the other will make sense...
I've Googled the holly hell out of this, no luck....
I drive a lowered Chevy, a lifted Ford and I have a 62 VW bug stripped down in the garage.
Which "Piss on" sticker do I buy?
vegas80step is offline   Reply With Quote
