I thought I would share some of the scary stuff I'm cutting off the K20. Note the sweet front lift blocks, add a leafs (Im thinking they took them out of the back pack) and the degree shims. lol!
1970 : Chevy: K20 "Frank the Tank" 6.0 LS, 4L80E, 14 bolt, and Dana 44 1970 K5 Blazer CST 350, TH350, Np205, Dana 60 and 14 bolt General Motors Master Certified wrench swinger ASE certified Master auto tech Instructor of Automotive Technology |
Re: Getting rid of the scary lift on my 70
Here is the awesome steering spacer that was broken in half. Nothing like relying on just the bolts to hold it together.
Wow! someone arrest the installer!!!
20' Daredevil (Ret)
![]() Join Date: May 2003
It's amazing to see some of the things people will do!
What suspension will you put under it?
I'm putting on a 4" Rough Country lift, with new Off Road Designs greasable rear shackles. As you can see from these pics the stock shackles were scary to say the least. The pass side inside one looked like someone had taken a torch to it at one point. It broke in half the second I tried to take it loose. The drivers was all bent and would hit the frame on a bump.
So uh... like how much would I be able to buy that used lift from you for??
![]() Sorry just had to ask, if I didnt some other smart a$$ would. Those lift blocks look pretty sketchy, and I was always told front lift blocks were a BIG no no.
1969 4x4 Nothing beats a good rock drill and some dynamite |
#7 | |
lol. This truck is full of big no no's
Some more pics of the new shackles and springs installed.
![]() Join Date: Nov 2011
Looks much better!
'29 Chevy 1.5 ton (2) '30 Buick 4 door sedans '57 GMC c.o.e. 2ton '72 Blazer CST '78 Camaro Z28 '97 S10 '05 Dodge CTD |
That looks a ton better!
Thanks guys. It wouldn't have taken much to make it look better than it did. Heres the new steering arm. I got new studs and cones to replace the 6" long bolts they had in there. The old ones didn't even come out that hard. Must have worked themselves loose from the spacer being broke.
20' Daredevil (Ret)
HUGE improvement!! I like the second pic above with the old setup visible in the background vs the new spring.
#13 | |
![]() Join Date: Feb 2007
![]() Looks good. Glad to see you got after it for safety sake. New suspension parts are always fun to show off.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
#14 |
Its amaizing how much better it drives already. I actually have steering wheel return and no crazy noises in the front. Now I just have to get the scary rear lift taken care of. More to come when I get that far...
#15 | |
#16 |
I drove it across the street to the drive through. I thought I was gonna die. The previous owner drove it down the highway on a regular basis. You couldnt have payed me to take it that fast.
#17 |
Just noticed, but does that truck have a sway bar in the front? The pad that the ubolts goe through are threaded like for the bolt that connects a sway bar. Im only asking cause the 76 front axle I just got has the same thing and I was thinking of using the sway bar if possible.
#18 |
No it doesnt have a sway bar. The PO swapped in the axle out of a newer truck. I put back on the right U bolt brackets without the holes drilled in them.
#19 |
Well I got the rear all done. Thought I would share the back custom-ness LOL
I gues that two pieces of 2" square tubing should make a 4" lift block, right?
#20 |
![]() Join Date: Nov 2003
Is your brake pedal a little soft?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#21 |
Lol no, actually. The hose pliers on the rear brake hose keep the pedal pretty firm. Im still trying to come up with some cores for my rear calipers. The parts store only wants $20 for the calipers but $36 for the dang cores.
#22 |
Wow stacked square tubing. Thats a GREAT idea
. Looks like you are doing a good job. Now to find those calipers.
#23 |
Look at the difference in the rear shock lenghts. The old ones were some rusty rancho 5000's I think they were older than me. Fully extended they were about 3 1/2 feet long.
#24 |
Wow! Thanks for sharing AND getting that deathtrap off the roads
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
#25 |
It actually takes more work to do it wrong, that's the sad part!
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
| Bookmarks |
