Old 02-18-2012, 08:15 PM   #1
hatred
hatred's Avatar
Need Brake Help
I have a 70 C10 half ton. Took the rear brakes apart last weekend and got a new drum and shoes. Here's where it gets tricky. I know the front end has been converted to 5-lug disc cause I had to buy a new brake hose, and had to get one for a 71. The rear is 5-lug drums. I've always seen the adjustment slot on the backing plate, but my rear has it on the drum itself. NONE of the parts places I went to, have a drum with the adjustment slot on it. The shoes are 11x2
The only number on the drums are...
Drivers = C2065 and 720295
Pass = 3989541
Any help at all would be greatly appreciated.
05 QSM GTO - M6, Corsa, King Springs
70 SWB CST - 350/Auto, Foose 18/17
I upset whiners too....
hatred is offline   Reply With Quote
Old 02-18-2012, 08:20 PM   #2
AustinScott
AustinScott's Avatar
Re: Need Brake Help
I ran into the same thing, I just drilled a hole in the drum big enough for my large flat blade screw drive to fit in. Worked perfect and I haven't had a single problem since.
AustinScott is offline   Reply With Quote
Old 02-18-2012, 08:50 PM   #3
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Need Brake Help
Interesting. My drums came from CPP and have the slot. I rarely use that slot tho...always felt it was more for maintenance vs install. I just tighten the adjuster so that getting the drum on is a tight fit and equal on each side. if needed...do a few back up stops to adjust.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-18-2012, 08:55 PM   #4
Redline novdog
Redline novdog's Avatar
Re: Need Brake Help
My new '67 6lugger drums had no slot either,drilled two holes and die grinder together.adjust at will.
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 02-18-2012, 11:08 PM   #5
hatred
hatred's Avatar
Re: Need Brake Help
The drum I bought must have been boxed wrong. Went to a different Autozone and the drum for a 72 had the knockout for the slot. Thanks for all the input guys!!
Tony
