02-19-2012, 06:24 PM | #1 |
454 questions
I recently bought my first classic truck. It is a 67 swb that had the original engine replaced with a 454. I have a few questions about the engine.
1. What vehicle did this engine come from? The number stamped into the top of the engine block is CG3300333. I've tried to research this number but haven't been able to find anything. 2. I want to add an a/c compressor. What do i need to do to install a compressor? The engine currently has a long water pump installed on it. Below are some pics to see the current set up. Any information would be greatly appricaited. |
02-19-2012, 07:40 PM | #2 |
Re: 454 questions
Get the casting number off the block. It's right behind the drivers side head. Then look on this list.
http://www.nastyz28.com/bbcmenu.php |
02-19-2012, 08:33 PM | #3 |
Re: 454 questions
Thanks Geezer.
It's a 75-87 block. |
02-19-2012, 09:04 PM | #4 |
Re: 454 questions
There should be a suffix code stamped on the engine pad under the alternator. If you can find it and read it, then looking up the code will give you the vehicle the engine was original installed in.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
