02-19-2012, 07:33 PM | #1 |
what is this???where does it go??and do??
This has been hanging under the dash of my 62 K10 since the day I got it. Yanked the old carpet today, and got tired of dodging it. Appears to control a heater comp. or something, has a long stiff wire with a curly q at the end, and there is a switch between the 2 screw holes that you can move with your thumb. Any ideas?
Thanks.
1962 Chevy K10 factory 4x4 stepside longbed http://67-72chevytrucks.com/vboard/s...d.php?t=494632 1967 Chevy 3/4 ton 4x4 long bed (Henrietta) traded 1968 Chevy 1/2 ton panel wagon, V8 and powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=483345 1978 Ford F250, beater stepside 2008 Jeep Wrangler 4 Door 2010 Chevy 4x4 plain jane work truck |
02-19-2012, 07:49 PM | #2 |
Re: what is this???where does it go??and do??
Hi trapperjack,
That looks like a turn signal switch. It should be mounted (with 2 screws) to the lower mast jacket of the steering column. That piece of stiff wire is a control cable that links it to the rest of the turn signal mechanism in the upper part of the column. I think 62 was the last year for that style of signal switch. |
02-19-2012, 09:17 PM | #3 |
That makes perfect sense. Looked it was supposed to mount to something round. and the column is gone. I'll cross that bridge when I find a new column.
Thanks Ray.
