Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-20-2012, 12:02 AM   #1
1971ls1longbed
1971ls1longbed's Avatar
bbc setup questions
Hey guys I have a few questions I need answered about some things. I'll give you the engine setup so far and hopefully someone can point me in the right direction.
454 block bored.030
Forged bottom end stock stroke
Keith Black 257 pistons
Cloyes timing set
990 rectangle port heads w/ 2.30 intake 1.88 exhaust with heavy porting
Comp solid roller lifters
Comp xr280r cam 242/248 @ 050 646/653 lift on 1.7 rocker power band is 2500 to 6500
comp magnum roller rockers
Compression is about 10.3:1
Rear gears are 3.73
Trans is a custom built 700r4
Stall is 2800
My first question is about headers. Should i use long tubes or shorties? Someone told me that shorties would help with low end torque.
Second question is what intake should I use? I was looking at an Edlebrock Air gap performer rpm dual plane.
Hopefully someone has some answers for me.
1971 Custom 10 LWB. 461 BBC and built 700r4 to be transplanted
1997 C3500 DRW Ext cab. 454, 4L80E daily driver
1971ls1longbed is offline   Reply With Quote
Old 02-20-2012, 12:30 AM   #2
redsled87
redsled87's Avatar
Re: bbc setup questions
I would use long tube headers. I think that intake would work for you.
1987 R10 Pump Gas 496/TH375
Best 1/4 pass to date
60' 1.49
1/4 10.93
MPH 120
redsled87 is offline   Reply With Quote
Old 02-20-2012, 02:01 AM   #3
1971ls1longbed
Im just asking because someone told me that shorties would help build better low end torque
Old 02-20-2012, 05:49 AM   #4
TheCustomFactory
TheCustomFactory's Avatar
They are backwards!! Longtubes help torque. Performer RPM airgap all the way. Very good choice for street engines. I would have to say the solid lifter cam is a bit much for the street but hey go big, why not?
TheCustomFactory is offline   Reply With Quote
Old 02-20-2012, 03:40 PM   #5
1971ls1longbed
Anyone have a good recommendation on a carb?
Old 02-20-2012, 04:28 PM   #6
TheCustomFactory
Holley street avenger 770 or 880cfm. Should help with the street manners.
Old 02-21-2012, 02:11 PM   #7
redsled87
redsled87's Avatar
Atleast an 850 or maybe even a 950. It is a BIG BLOCK.
60' 1.49
1/4 10.93
MPH 120
Old 02-21-2012, 09:39 PM   #8
Blue Rat
Sound like a good job for an 800 DP in the HP series to me. You could go 850 but it would be nice to try both. Depends on the weight of the vehicle. With that gearing think an 800 would be fine.
Blue Rat is offline   Reply With Quote
Old 02-26-2012, 07:49 PM   #9
1971ls1longbed
Im using 3.73 gears
My next question is should i use a mechanical fuel pump or an electric
Old 02-26-2012, 08:34 PM   #10
Blue Rat
Either pump would feed it good.
Old 02-26-2012, 09:14 PM   #11
1971ls1longbed
Ok i guess my dilemma is would one benefit me better than the other
Old 02-27-2012, 08:55 PM   #12
Blue Rat
I think with everything in your setup. I would have to go with an electric pump. You can take the fuel pump rod out then an block it off.
