Old 02-20-2012, 12:29 AM   #1
Tmwoodall
Cleaning Underside of Cab
I am looking for opinions here, I have a true zero* rust 72 cab (*except for one small bit I found on the inner rocker DS, which was cut out) I am about to flip the cab over on its back tomorrow and decide how to proceed. The factory undercoating, or what I assume is factory is still on there. I believe it is a rubberized undercoating. I started to strip it years ago with a wire wheel and it was stuck pretty well. Even that spot is still clean and rust free. My question is should I take some aircraft stripper to the cab and get it down to bare metal, or in your opinion is it ok to leave the old stuff on there and topcoat?
Ideally the consensus would be to leave it since it has held up this long, but I know that may not be the case which is why I am asking.
www.tomthetruck.blogspot.com <-- Aka build thread.
Tmwoodall is offline   Reply With Quote
Old 02-20-2012, 11:31 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Cleaning Underside of Cab
As long as it is stuck good it shouldn't hurt to leave it. If you want to remove it you could probably warm it up with a heat gun and scrape it off.
LockDoc
Leon
Old 02-20-2012, 11:44 AM   #3
midniteblues
midniteblues's Avatar
somtimes its a stinky job a good knotted brush on a angle grinder helps too but its messy good luck
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 02-20-2012, 11:46 AM   #4
Tmwoodall
Thanks guys, that is what I am thinking now too after further consideration. I am going to look it over and see, but if it is truly stuck I'm going to clean up what is there and topcoat with some bedliner.
Old 02-20-2012, 11:52 AM   #5
no moa
no moa's Avatar
Just don't forget to cover the threaded holes, a buddy up here didn't do that, and the bedliner got in the holes, he spent hours with thread taps trying to clean them out. lol
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 02-20-2012, 11:54 AM   #6
Tmwoodall
Ah, yes, good reminder. I learned that lesson on my Wrangler when I did the interior. It was not fun remounting a few of the items.
Old 02-20-2012, 02:34 PM   #7
downbytheriver
downbytheriver's Avatar
Not to sound drastic, but if I'm not mistaken, that undercoating has asbestos in it. I would be hesitant to sand it without using the proper protection if that's the case.
Just know that stuff is super nasty, not trying to stir up any pots. I could be wrong (wouldn't be the first or last time ) though.
downbytheriver is offline   Reply With Quote
Old 02-20-2012, 02:38 PM   #8
Tmwoodall
Interesting. I have a 3m vapor/particulate filter but still that makes me nervous. If that is the case i may just wipe it down and spray over it.
Old 02-20-2012, 03:44 PM   #9
downbytheriver
Like I said, I can't be 100% sure if it does or not, but better to be safe than sorry.
If you use proper protection and use a heat gun/scraper instead of sanding or some other method that causes the particles to be airborne, then you'll be okay. It comes down to friable vs. non-friable material as far as I know, which is very little.
