02-20-2012, 10:21 AM | #1 |
Radiator mounts
Need help with figuring out what radiator mounts will work for my 1967 chevy c10. I bought a 4 core radiator off member dano but not sure what years if 68-72 c10 and c20 will work. Also if i do i was told just to bend the bottom a bit with pliers so the bottom brackets fit. Main question as well would be how do i set the bottoms in? By tack welding them? and from your experience and a junkyard/salvage yard how do you get them off being the Originally are rivit in? Thank you.
02-20-2012, 10:45 AM | #2 |
Re: Radiator mounts
The radiator support will need to be modified. I used a cut off wheel to cut the support then bend flat. The 4 core mounts will line up, then I just used small carriage bolt to hold them in place. Kind of tricky to get nuts on because of the frame but it will work.
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. |
02-20-2012, 11:00 AM | #3 |
The Older Generation
Re: Radiator mounts
The year really doesn't matter you just have to get the top and bottom 4" radiator support brackets. You don't modify the brackets, like Daddy said, you modify the core support. You can find them in salvage yards that still have some older stuff, on the parts board here, or buy them new. Here is a thread that shows pictures of the difference. http://67-72chevytrucks.com/vboard/s...d.php?t=345832 LockDoc LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 02-20-2012 at 11:07 AM. |
02-20-2012, 11:26 AM | #4 |
Re: Radiator mounts
Thanks fellas thats all i needed to know.
