![]() Join Date: Dec 2011
TH350 shift linkage question
I am building a new exhaust system for my 69 long bed. Does anyone make an aftermarket shift linkage that deletes the bracket that mounts to the frame? Or can I remove it and use the stock linkage? It would make a lot more clearance for my exhaust if I can do that.
Thanks for any help you can give me.
1966 C10 short step bagged 383 |
Re: TH350 shift linkage question
Someone has done that mod and posted picks. Might try a search. I'll poke around and see if I can find it.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Member #1049
I have used this setup in many different cars/truck
http://www.summitracing.com/parts/LOK-ACA-1800/ |
![]() Join Date: Dec 1999
LOKAR makes one.
Livrat, did that fit the stock chevy column with the TH350? Looks just like what I am looking for, thanks.
GEARHEAD
It's the same one I used. I had to make a small bend in the rod to get rid of some binding, but works great and was easy to istall.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
Thanks, just ordered it. Thanks all for the info.
