Old 02-20-2012, 01:31 PM   #1
vazquezguitarras
vazquezguitarras's Avatar
Vacuum help!
Hello boys! Need help with this. Anyone know where this is connected and serving? Thank you!
vazquezguitarras is offline   Reply With Quote
Old 02-20-2012, 03:39 PM   #2
grs
Re: Vacuum help!
Show a picture of the whole thing that it is connected to.
grs is offline   Reply With Quote
Old 02-20-2012, 10:00 PM   #3
vazquezguitarras
Re: Vacuum help!
This valve opens and closes a gate housed in the exhaust manifold, but no where to connect the outlet hose. Thank you very much for your help!
Old 02-21-2012, 01:57 AM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Vacuum help!
Looks like the heat riser. Closed when engine is cold and pushe exhaust through the head and warms thi intake and engine faster. Then opens once engine is fully warmed
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 02-21-2012, 02:17 AM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Vacuum help!
We have a winner!! The diverted exhaust warmed up the carb. Think of it as an EGR valve at idle when the engine is cold. Vacuum was controlled by a thermatic thinging on the intake air cleaner housing.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 02-21-2012, 11:14 AM   #6
vazquezguitarras
Re: Vacuum help!
Thanks guys, but I still do not understand where you connect the valve to run this system.
Old 02-21-2012, 11:15 AM   #7
vazquezguitarras
Re: Vacuum help!
Old 02-21-2012, 11:15 AM   #8
vazquezguitarras
Re: Vacuum help!
Old 02-21-2012, 11:23 AM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Vacuum help!
could run off a thermal switch on the stat housing
maybe you have seen this type,same idea
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-22-2012, 09:09 PM   #10
vazquezguitarras
Re: Vacuum help!
Thank you very much, your contribution was of great help!
