Junior Member
Can u tell from vin if a truck has 1" or 1.25" rotor?
see above
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
Garage wrench
Re: Can u tell from vin if a truck has 1" or 1.25" rotor?
no sir
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
Pull the wheel off and measure outside to outside of the rotor. You'll know right away.
RIZ |
BAD BOW-Silverado XST
Check the RPO codes. Heavy Halfs, fleet trucks and special orders had them.
![]() Join Date: Apr 2009
My 87 is a "Heavy Half" with 1.25" Rotors.
It has two RPO codes , "JB5" and "J55" JB5 Brake System: Power, Front Disc, Rear Drum, 6400 Lbs. JB5 BRAKE POWER, DISC/DRUM, 6,400 LBS J55 BRAKE SYSTEM HEAVY DUTY Desert |
67-72 parts collector,…
![]() Join Date: Nov 2002
The best way is to measure.
I had an '86 with the HD rotors and an '83 with the light duty rotors. I'm not sure what GM was thinking. I know all the 71-72 front ends are 1-1/4". I think all the 73-80 front ends are also 1-1/4". 81-87 is anybody's guess,...
#7 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Junior Member
I will pull the wheel and check it out. I was in front of the computer at work and was trying to figure it out.
Right. That would be the smaller power brake system.
I know there was a manual system available as well, JB1 perhaps? It just occured to me that, during our recent move, I found the actual component charts that we use/used to release the specific brake hardware for the various systems - from 1979 or so. I'll see if I can find it again and post it up. K
6.0 powered square
my 80 big 10 had 1" rotors that some one swap in, but it now has 1.25 rotors front and rear
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
C35 Crew Dually
off topic but kinda the same but I went to order front pads for my CC dually and they asked me what size my rear breaks were? the sizes were 13.2 1/2 or 13.3 1/2 where do i measure?
sorry for the thread jack
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 |
#13 | |
Here is one of many resources. http://www.c2e.info/rpocodes/gmrpocodesGthroughM.html JB1 BRAKE, MANUAL DISC/DRUM 4300 LBS Dez |
#14 |
Ok - as I mentioned, here are the actual charts that were used by the design engineers to release the various brake components. You can see the hardware sizes, bore dimensions, friction material, etc and breakdowns by part number.
Based on the '87 chart it looks like the 1" rotor was used only on the two smallest systems, the JB1 manual and the lightest JB3 power. You should be able to tell by looking for your truck configuration on here: 1974 and 1987 shown: ![]() ![]() I'll post the complete set as a reference in a separate thread. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 02-22-2012 at 08:12 PM. |
#15 |
easiest way is to stick your index finger in the holes that run along the edge of the rotors. I if you finger goes in its 1.25 if it doesnt its 1"
works for me. lol
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
