Old 02-21-2012, 12:46 AM   #1
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Changing Starter Help.
Hey guys,
Bad news. After scouts tonight my starter crapped out on me. Won't even turn over. Jumped it off a friends truck, nothing. This happened a couple of days ago and I thought my alternator died because I was able to jump and start so the alternator was replaced.
Now I have to leave my truck in a parking lot till tomorrow. Step-dad is going to pick up a starter for me so we can replace it but I have no idea how.
Can anyone tell (or post pics) of how to change one?
Thanks...
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 02-21-2012, 12:55 AM   #2
Fixwhataintbroke
Enthusiast
Fixwhataintbroke's Avatar
Re: Changing Starter Help.
its a video but its pretty much the general procedure: (skip to like 1:15 for where he actually starts doing anything)
- Cole
1979 Chevy C30 w/ carb 454.
1992 Chevy K1500 w/ tbi 350. *Sold*
1997 Dodge Ram 1500 w/ Magnum 360 *Sold*
"Good judgment comes from experience. Experience comes from poor judgment." - George Washington
Fixwhataintbroke is offline   Reply With Quote
Old 02-21-2012, 03:03 AM   #3
irishman999
irishman999's Avatar
To get it to start to get it home smack it with a hammer. Really crank on it, I guarantee it will start. Other than that its just a couple 9/16's bolts holding the starter on as well as the connections on the terminal. Shimming might be required, I am learning about that right now.
irishman999 is offline   Reply With Quote
Old 02-21-2012, 10:58 AM   #4
Zebb
Zebb's Avatar
Disconnect your battery first.
Zebb is offline   Reply With Quote
Old 02-21-2012, 11:00 AM   #5
old crewcab
Originally Posted by THE "10" SILVERADO View Post
Hey guys,
Thanks...
dont know if you have checked this or not, but check the battery wire connection at the starter. i had similar situation once, cold and at night, so i got permission to leave truck gas station parking lot. next morning took battery & alt. to get checked (both ok). so when crawling under the truck to "TAP" on the starter, i noticed the battery wire to the starter was loose. tightened the nut...and the parking lot repair finished and down the road i went!! FROZEN BUTT and $0 repair bill.......(almost) priceless!!!!
old crewcab is offline   Reply With Quote
Old 02-21-2012, 11:31 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
up here heat/salt will bake/corrode,green the wires down there
if you can get the cap off the connections sometimes that big batt post can be turned inside and is ok and reused,sometimes replaced is better tho
make sure power is good before replacing
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
