Old 02-21-2012, 02:36 AM   #1
KQQL IT
At the body shop.
KQQL IT's Avatar
3/4 ton to half ton spindles?
Does any body make a drop spindle for a 3/4 ton that will use a 1/2 ton rotor and caliper.
Or get a 1/2 ton spindle and get it reamed to 3/4 t ball joints. Or what options is there.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 02-21-2012, 07:28 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 3/4 ton to half ton spindles?
www.earlyclassic.com sells the "conversion spindles".
Give them a call.
As far as I know,... they are the only company that makes these.
Keith
Convert to disc brakes.
Old 02-21-2012, 01:41 PM   #3
KQQL IT
At the body shop.
KQQL IT's Avatar
Hey thanks for the info.
I also shouldve mentioned square body...
But they do have that spindle.
Old 02-21-2012, 03:23 PM   #4
lolife99
lolife99's Avatar
Yep.
They make a set for that says "71-87"?
Kinda weird, because the 71-72 trucks use a different upper ball joint and outer tie rod end than the 73-87 trucks.
I would call to confirm with Stan this.
My guess would be that these work with the 73-87 parts.
Keith
Old 02-22-2012, 12:42 AM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
I called them.. theyre an hour away from me.
Its my bro n laws crew cab square. Want to drop it 4/6 or so and i have a 5 lug 12 bolt for the cause. Were kinda torn on how to do the front. Stock spindles reamed for 3/4 joints and cut coils or spindles and clip one coil.
