Old 02-21-2012, 08:14 AM   #1
xrcr
wiper delay
84 cab, 84 interior harness, wanting to know where the intermittent wiper module hangs. Thanks for any help.
xrcr
xrcr is offline   Reply With Quote
Old 02-21-2012, 09:19 AM   #2
ges55
BLACK SATIN
ges55's Avatar
Re: wiper delay
My 85 Silverado has it under the steering wheel behind that panel.
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new
67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering
85 C10 Silverado- 305ci
ges55 is offline   Reply With Quote
Old 02-21-2012, 01:09 PM   #3
xrcr
Re: wiper delay
That's what I figured but haven't figured exactly where the right spot is. When I bought the cab it didn't have a column in it. At least I'm close....
Thanks,
xrcr
Old 02-21-2012, 11:01 PM   #4
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: wiper delay
If your wiper switch is dash mounted then it is inline right behind the switch itself.
But if it's on the turnsignal arm then the delay module will be mounted under the column and behind the dash. It simply slides onto the bracket shown below.
Couple of tabs on mine are broken off....
And the bracket it mounts to.....
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 02-22-2012, 08:07 AM   #5
xrcr
Re: wiper delay
BLE'BURBAN. That's the pic I needed. I was figuring the way the plug was pointing it had to go there somewhere. I was dead set that the plastic tit was the hanger wasn't sure what the clips on back did.
Thanks again,
Jim
