Anyone know where I can get some a arm bushings for 63-72?
I got an extra set of A arms off of a 2nd gen c10 to put on my 66. I want to rebuild them while they are off of the truck, but I can't find just the bushings. I can find the cross shaft kits but not just the screw in bushings.
Also, what is the difference between 1st/2nd gen A arms vs 3rd gen arms? I know the 3rd gens have rubber pressed in bushings, but can those bushings be used on the older arms if you swap out the cross shafts? Posted via Mobile Device
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201 no garage, no shop, limited storage space and tools....no problem. |
Re: Anyone know where I can get some a arm bushings for 63-72?
Napa?
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
Newer arms can be used on earlier trucks. The steering stops are slightly different between drum & disc spindles so there is a slight difference @ full lock turning.
Checked online and they only have the full kits. I'd like to just get the bushings to save some money.
LMC Truck. Just ordered mine this week.
