Old 02-21-2012, 03:02 PM   #1
Stefan.
Stefan.'s Avatar
Lamp "Over Speed"
When i switch on the headlights, the yellow Lamp "Over Speed" in the instrument housing switch-on. ( I drive not)
What say this Lamp to me?
Stefan. is offline   Reply With Quote
Old 02-21-2012, 03:15 PM   #2
64fleetside
Re: Lamp "Over Speed"
It means someone prolly stuck a dash lamp into the wrong hole-the overspeed indicator was used only on big(1 1/2 ton-up) trucks with the rev limiter.
64fleetside is offline   Reply With Quote
Old 02-21-2012, 03:58 PM   #3
Stefan.
Stefan.'s Avatar
Ok! Thank you.
Old 02-21-2012, 06:59 PM   #4
ChevySixty6
ChevySixty6's Avatar
There are 2 lights that aren't normally on. The 'overspeed' and if i remember
something about brakes rings a bell. Anyways, when i changed my dash out for a full guages instead of idiot lights, i screwed up. There were 2 cardboard tubes with a dark green cover on one end. The open end popped into the back of the lens and just stayed there. It might have gone all the way to the circuit board back. That way the light from the dash bulbs can't pass through the green and light up the lens. I didn't put those back on. Just forgot about it till i turned on the lights, then magically i had two previously unlit lights light up. I'm probably gonna put two stickers of some sort on them, till i tear it apart again. They are fairly bright.
Members i've met: LiLRed66
ChevySixty6 is offline   Reply With Quote
Old 02-21-2012, 08:08 PM   #5
62 mark
62 mark's Avatar
I had a dash lite that said 'Tandm loc" in one of my trucks...
62 mark is offline   Reply With Quote
Old 03-19-2012, 12:15 AM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I used the google search feature at the top of the forum and typed "over speed".
This thread was top on the list.
The gauge cluster I got with some other stuff had the "Over Speed" light.
Thanks for the answer.
66 C20 Service Truck:
