Old 05-01-2003, 11:55 AM   #1
Tink
Tink's Avatar
Looking for advice on buying a 70 K10 *Updated*
My husband and I might have the chance to get a 1968 K10 (or maybe it's a K20?). It is a longbox, has a 350, is in rough shape (bodywise) and has some wiring issues but it runs. It appears to be lifted about 4 inches and has a winch on the front. Haven't seen it up close... it is sitting in a field right now.
Anyhow, what should we look for and what do you think is a decent price to pay for a truck like this??
Thanks!
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Old 05-01-2003, 12:10 PM   #2
Scottri
Scottri's Avatar
Look for rust around the rocker panels, the cab corners and the front fenders. Another big factor for me would be original parts. What is there and what isn't. Is the motor correct for the truck. Does all of the running gear work correctly? I would also make sure all of the body panels are correct for the year such as front fenders and hood, grill and such. Some people have mixed and matched parts from different years. It will work but it's not correct for a true restoration.
Electrical problems are not hard to sort out for these trucks. Just about any part you could think of is still available and they are very easy to work on.
I can't really help with the value since I'm not from that area but here in Portland Oregon I would say maybe $1500 if it's all there. They are pretty common around here.
Scott
1969 GMC 3/4 Ton Long Bed Fleetside
350, 4 speed manual, P/S, P/B, Edelbrock 1406 Carb
Beaverton / Portland Oregon
Scottri is offline   Reply With Quote
Old 05-01-2003, 12:51 PM   #3
Hutch
Hutch's Avatar
Tink,
Check the frame for cracks near the steering box mounts and where the transfercase mounts to the frame.
These are usually hidden from site due to grease build up.
Frame problems are something to be aware of up front due to the complexity of the issues.
Check the vin numbers and the options sheet listed on the glove box to see if the numbers match.
I would not think that a winch or lift kit would add to the price
Have fun
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 05-01-2003, 01:00 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
Problem areas/Tips:
1. Check for cracks in frame where steering box bolts. This is a major stress point.
2. Frame rust through. Especially hardest hit is LH framerail between cab and rear wheels.
3. Rear spring hangers, again rust-through prone.
4. Cracked leafs, front and rear.
5. If original, transfer case is a rockwell. Hard to find parts for these.
6. If original, it should be a standard, no auto 4x4's were made until 1970.
7. If original, front axle will be a closed knuckle Dana 44, a less servicable design than the open knuckles used 70-72.
8. Look at lift, I'd be wary of too much "backyard" engineering if done incorrectly.
67/68 4x4's do not share some chassis parts with 69-72 years. Most notably the steering box/pitman arm and the rear shackle and springs. Parts chasing on these can be tougher and more expensive.
Don't shy away from it based on me, just go into it with your eyes open. Good luck.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 05-01-2003, 01:02 PM   #5
CPNE
Resident Curmudgeon
CPNE's Avatar
Wow hutch, you and I are on same page with tips, I just type slower!
Old 05-08-2003, 07:10 AM   #6
Tink
Tink's Avatar
Thanks for all the advice!
Well, the truck is a 70 K10, has newer rockers and fenders but the doors are toast. It has a race built 350, a body lift and all-terrians. He is asking $1000 for it.
However, I can't get a hold of him so we can really see it!! He needs to invest in an answering machine! I'm about to call at 5AM when I get up!
69 Chevy C10
88 Sierra
02 2500 Suburban
Old 05-08-2003, 09:51 AM   #7
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
LOL if ya call me at 5am the price woulda doubled!!!
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-08-2003, 01:54 PM   #8
neonlarry
neonlarry's Avatar
At least in CA, any running 67-724x4 will go for more like $2500 and up, even if it isn't all that nice. But there are very few 4x4s of thses years here.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
